As a "GeForce GTX Titan II" might look
Thursday 18 April 2013
/ By Leonidas
The GeForce GTX titanium currently leads - despite the contradictions that the exorbitant price point - all the charts on the performance of single-chip accelerators clear, a slimmed version is also in the form of the GeForce GTX Titan LE already on the way. It even has the original GeForce GTX titanium already a (small) Abspeckung - the card is not known, provides all the hardware units of the underlying GK110 chips on. This of course is due to the fact that a well-officially 561mm ² large graphics chip can not be made really easy and especially not without certain rejection rate. By means of in the original GeForce GTX titanium unlocked only 2688 of original 2880 shader units do not rely on entirely perfect from the GK110 chip manufacturing, which just might initially help tremendously.
Over time, the GK110-production but will be automatically better, the Aussschussquote will continue to decline - and thus accumulate a certain number of GK110 chips, which are made absolutely perfect. This perfectly crafted GK110 chips can then certainly wasted in the production of the original GeForce GTX titanium - or you put on a new, higher titanium variant, called by us the following simple once "GeForce GTX Titan II". This map would include eventually offer the full extension of the GK110 chips even higher clock rates and therefore could be in the frame (depending on clock speed) of 10 to 15 percent drop off performance of the original GeForce GTX titanium.
Until now, this is of course only one (theoretical) option available - this is interesting only if nVidia can do something with this Möglichekeit. This depends on the medium-term plans to nVidia, which are still clearly unsure as opposed to AMD. But accepted the point, the next (real) generation of graphics cards from nVidia is identical to AMD's plans for the Radeon HD 8000 series until the year 2013/2014, could be a "GeForce GTX Titan II" for the GeForce 700 series the same take part as now for the GeForce 600 series - as a top card clearly above the level of performance of the subsequent accelerator.
This would be more important than that we the top models of the Radeon HD 8000 series already close to the original GeForce GTX titanium estimate . To lie back a decent distance performance to the Radeon HD 8970, nVidia needs just a little faster than titanium card is now offered. If so Radeon HD 8000 and GeForce 700 series (for desktop issues) really only appear at the end, would be such a "GeForce GTX Titan II" ideal for nVidia to the currently observed state of the titanium as clear about all enthroned performance produce winners again. The technological possibilities has to be, because the orginal GeForce GTX titanium the possibilities of the GK110 chips as I said not yet exhausted.
With a solid expansion of the GK110 chips and something higher clock rates interesting things are quite possible: On approved 950 MHz clock - which seems very achievable given the overclocking results of the current GeForce GTX titanium - would be 16.2% more computing and Texturierleistung come. Assuming a slightly increased memory clock - for example, at 3400 MHz, which is 13.3% more memory bandwidth results - this increased computing power would be well more immutably in performance. In this (currently only theoretical) model would certainly be close to 15% more power than the original GeForce GTX titanium achievable.
http://www.3dcenter.org/artikel/wie-eine-geforce-gtx-titan-ii-aussehen-koennte
Pinch of salt as always
