£1100ish spec please
26 Apr 2011
I have PSU/case, need the rest...
Needs 16gb ram, 256Gb SSD, 2tb other drive and a decent 27 inch monitor. I want to run a resolution larger than 1920x1200, doesn't need huge FPS, but should be decent in games.
I will never overclock.
A quiet PC would be fantastic.
Any reason why you need 16GB of RAM?
& With that budget it may be worth waiting until Haswell is released.
Do you need an OS, and what PSU/case do you have?
I have a Lian Li mid tower case, not sure of model and a 520w corsair modular PSU. No OS needed. The 16gb is for VMware virtual machines.
Just started reading about Haswell now that you mentioned it, june isnt far off.
I don't mind spending a bit more on a better monitor, what's a good 27" these days?
TBH. the choice of 27" monitors on here is limited, even more so for high resolutions. So you may have to look further a field.
Apart from the one already specced, these are the other 27" monitors with high resolutions. As to how good they are, can`t really say.
YOUR BASKET
1 x Viewsonic VP2770-LED 27" Widescreen Professional LED Monitor - Black £599.99
1 x Dell UltraSharp U2713H 27" Widescreen LED Monitor - Midnight Grey £599.99
1 x Asus PB278Q 27" Professional LED Multimedia Monitor - Black £539.99
1 x Dell UltraSharp U2711 27" Widescreen LCD Monitor - Midnight Grey £499.99
1 x Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey £409.99
Total : £2,689.43 (includes shipping : £32.90).
Try opening a thread in the monitor forum, you will probably get better feed back.
http://forums.overclockers.co.uk/forumdisplay.php?f=85
