Hi there
I've further reduced to DELL Screens further for the remainder of our THIS WEEK ONLY offers, these products come of This Week Only tomorrow morning, so you literally have less than 24hrs to act:-
Dell UltraSharp U2913WM 29" Super-Widescreen LED Monitor - Midnight Grey @ £379.99 inc VAT
Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with a 21:9 aspect ratio and 2560 x 1080 Wide Full-HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178°/178° (typical) ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
Experience remarkably precise and accurate color made possible by over 99 percent sRGB at a delta-E of less than 5, offering broad color variation. Plus, the U2913WM comes factory color-calibrated, so you can enjoy outstanding color accuracy right out of the box.
Make it work for you, with extensive connectivity such as DisplayPort 1.2, USB 3.02, Mini DisplayPort, DVI and HDMI, plus highly adjustable tilt and swivel positioning, a 130mm height adjustability range and a VESA-compatible wall mounting option (mounting kit sold separately).
Synchronize your applications and improve your visual experience. Dell Display Manager offers a variety of features that can optimize your media presentation and maximize your monitor’s real estate, such as Easy Arrange and Auto Mode.
Automatically optimize your video settings with the Smart Video Enhance3 feature, optimizing colors and sharpness for the best possible presentation. Choose Movie mode for recommended settings, or choose Advanced mode to manually adjust contrast, sharpness, color saturation and hue however you like.
Stay energy-efficient with PowerNap and dynamic dimming features that automatically help regulate power usage. Plus, the U2913WM features an eco-conscious design with arsenic-free glass, mercury-free LED and BFR/PVC-free laminates in the chassis. The U2913WM is EPEAT® Gold and ENERGY STAR® qualified and comes packed in eco-conscious recyclable packaging.
Specification:-
- Panel: 29-inch (73.02cm( (diagonal) VIS with LED backlights
- 21:9 aspect ratio
- LED Technology
- Contrast Ratio: 2,000,000:1
- Brightness: 300cd/m
- Response: 8ms
- Resolution: Wide Full-HD 2560 x 1080 at 60 Hz (Max)
- Viewing Angles: 178°/178° ultra-wide viewing angle
- In-plane switching technology
- Color calibration factory report
- More than 99% sRGB (deltaE < 5)
- Input Connections: DisplayPort 1.2 / mini-DisplayPort, DP-out, HDMI, DVI-D (HDCP), VGA
- USB3.0 Hub (4 downstream / 1 upstream)
- Tilt, swivel and height adjustable (130mm)
- Option to wall mount in landscape and portrait mode (VESA 100mm x 100mm)
- Arsenic-free glass and mercury-free LED panel
- Dell Display Manager - Auto mode, PowerNap, Easy Arrange, Smart Video Enhance
- ENERGY STAR®, EPEAT Gold, TCO Certified Displays, ErP Standards compliant
- 3yr Onsite-Warranty
Was [£449.99] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £399.95 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Brightness: 350cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was [£479.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
This is unbelievable pricing for DELL and the prices are going up considerably tomorrow, so get your wallet out now and bag yourself a truly awesome monitor with superb after support.
Specification:-
- 21:9 aspect ratio
- LED Technology
- Response: 8ms
ORDER NOW
Features:-
- LED Backlit
- Height Adjustable
- 5-Port USB3.0 Hub
- VESA Compliant
- Weight: 10.20kg
ORDER NOW
