Don't worry so much about size, manufacturers are never true to real sizes anyway, ones 2.1 could be another's 2.3 etc, always a bit of difference. You want to look what tyres you've got on now and then pick some that will be better, tell us what you're running now and there is bound to be a few opinions.
). Not fitted yet, so not had a chance to have a look.They're Kenda tyres but I think the model has been superseded as I can't find them anywhere.
They actually 26 x 2.1
Front:
Back:
The back tyre is starting to look a bit worn in places so replacing it wouldn't be bad.
Any suggestions are welcome.![]()
What pressure do you run? Anything higher than 40psi is going to feel skittish. I would try 35 but beware of pinch flatting.
You calling me fat Cow? Eh? Are ya?Even when I was on tubes/trail bike I didn't have it that hard, and at 82KG im not light either.
Im not heavy, lightish at 82kg. Edit: but I am a bean stalk![]()
