Intel or AMD and which motherboard?
10 Jan 2013
Hi,
This will be my first computer build. I am mainly building this to stand up to the rigours of the software I will be using for my Masters in mechanical engineering. Whilst also having the power to play some of the latest games being a bonus.
So far I have been looking at either the AMD FX8350 or the Intel Core i5 3570k.
I will be mainly using multi threaded applications such as ansys workbench. I will also require the computer to be able to be a media server at the same time using Serviio.
Any advice would be welcomed as I am unsure of which motherboards work with the FX8350 and I have a budget of around £700. I do not need to include the Operating system or SSD in to this budget as I already have these but everything else required for the tower. I am also looking to ensure that it is expandable in future, for example being able to add a 2nd graphics card or more RAM
YOUR BASKET
1 x HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card (H795F3G2M) £239.99
1 x AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail £149.99
1 x MSI 990XA-GD55 AMD 990X Chipset (Socket AM3+) DDR3 Motherboard £79.99
1 x Seasonic S12II 620W '80 Plus Bronze' Power Supply £64.98
1 x Corsair Carbide 200R Compact ATX Case - Black £49.99
1 x Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP4G3D1608DE1TX0CEU) £43.99
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
Total : £672.42 (includes shipping : £11.25).
Or knock the cpu back to an 8320 and gpu back to a 7850...
YOUR BASKET
1 x MSI HD 7850 OC 2048MB GDDR5 PCI-Express Graphics Cards £164.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £129.95
Total : £576.48 (includes shipping : £10.50).
or the intel routes...
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £112.99
Total : £734.52 (includes shipping : £10.50).
7850 instead of 7950...
YOUR BASKET
Total : £659.52 (includes shipping : £10.50).
Intel is the best option, The i5 is the better choice for games and IIRC Ansys workbench only uses two cores unless you upgrade to a more expensive licence. If you're throwing that kind of money around then the 3930K will destroy the i5 and the FX-8.
As an alternative CPU check out the Xeon E3 1230 V2.
Priced similarly as the 3570K it is essentially an i7 without the integrated graphics which, if you're planning on using a discrete graphics card anyway, could make it a great option.
YOUR BASKET
YOUR BASKET
YOUR BASKET
YOUR BASKET
the g-cards in these arent great, the specced 7950 has a base lower clock speed than all the other 7950s and the msi card isnt great (i have had to rma 2/3 of my msi cards) for a 7950 this would be better http://www.overclockers.co.uk/showproduct.php?prodid=GX-065-HS&groupid=701&catid=56&subcat=1673 and 7850 http://www.overclockers.co.uk/showproduct.php?prodid=GX-052-HS&groupid=701&catid=56&subcat=411
Sadly I am only using an academic licence of Ansys. So I am unsure as to whether it will use more than 2 cores as when using the uni computers which have 4 cores. They were still usable so I imagine it is only a 2 core licence
that sucks having anything above an i3 with that would be pointless you might be better just throwing in a copy of windows home premium
I'd get the i5 then, core for core performance will be more important.
Can't clock the i3 like you can an i5K, so it'll be much less core for core performance.
but if it is a core locked license then he won't be able to make use of the i5 and either would be better geting an i3 or an i5 and throwing in a copy of win 7 home premium
He may be only able to use 2 cores but the i5 being about 1GHz faster as stock plus overclock-able is a big bonus, plus he wants to run a media server in the background.
