FRAPS
30 Dec 2009
Wigan Lancs
Does anyone use FRAPS? and is there an alternative that's easy on the frame rate.
I like using Microsoft FSX and the frame rate plummets by about 50% when I use FRAPS.
Thanks.
I use MSI Afterburner when capturing live gameplay, I only use FRAPS if I'm spectating or replaying a recording/demo of something.
if you record with afterburner or any recording device, if you can have the recording recorded on a different drive to the game your playing.
my seagate barracuda 7200rpm drive couldnt read and write quick enough on skyrim at 1080p in busy areas
I didn't even know you could record with afterburner. I'll have to try this :)
DXTORY is the best atm i think, sepaerate audio tracks, makes editing way easier, good options but large files unless you record with the Lagarith codec :)
