SB E supports PCI-E 3.0 so it will defo be in Ivy E.
Well if we have enough good silicon I certainly can look at doing this as I will be testing enough for me and my systems.
Mine doesn't seem to
10-20% of the time when I start my PC with PCI-E set to 3.0 I get no display. Setting to PCI-E 2.0 solves the issue.
I think its like get boxed one. Test it. Sell as OEM
I am ok with that![]()
You need to download a patch from Nvidia IIRC, as standard their drivers won't work in PCI-E 3.0 mode on an X79 board, I *think* their official word was somehting like X79 came out before PCI-E 3.0 was officially ratified and so as diff manufacturers may have gone slightly diff on the specs most boards are only draft 3.0 compliant or something odd like that, so to avoid issues Nvidia drivers won't do PCI-E 3.0 on X79 unless you download and run a batch file from Nvidia.
I had to do this to get my GTX670 FTW to use PCI-E 3.0 on my P9X79.
  and nvidia followed suitThe unsuspecting people buying 'brand new' OEM chips, that were pretested and so guaranteed to be bad clockers, won't be ok with that though![]()
How does that work exactly, you open all the sealed cpu's, test them, and sell the worst clockers as brand new products to unknowing customers?
Or am I missing something![]()
