7970/50 Arctic Accelero Users
Just a quick update...
I've been in touch with Jens at Arctic and he said
To which i said
Immediately after pressing send i regretted laying my cards so bluntly on the line to Jens. Thankfully he took it in good spirit and didn't get a restraining order placed on me.
A few more mails continued and he forwarded me on to some potentially strange man called Cedric from their American department and he is going to see if they can sell me one directly.
If i manage to get my hands on one of these, i will be pretty much the only man with one in the UK. That alone makes me want it even more than i did originally. :p
P.S Don't even attempt to talk me round from buying it, you'll just be wasting your time. :D
Its looking good, Jens says they are checking the shipping costs and will come back to me soon. Cedric my main man delivering the goods, literally in this case.
Matt, when you get your new cooler and your going to take off your accelero - can you make us that video about installing the accelero properly? :)
Yeah, either that or ill take loads of pics. I'm thinking about giving my pcb a bloody good clean as it has a fair bit of the adhesive on it and its a bit of a pain to get it off. You have to pour lighter fluid on the adhesive and the pcb to loosen it. Done it a few times though now and it works well, just takes some time. The good thing about lighter fluid is it evaporates quickly so within a couple of hours you can use the gpu again.
thanks - this would be very helpful
which leads me back to using that thermal tape :p
My awesome luck never ends. Turns out my RMA replacement card was DOA. I took it out of the box and plugged it in and nada. Tried everything to get it working and nothing worked. Anyways i talked to them and they were supposed to pay for the shipping but for some reason the don't do it for Canadians for another $30 for that. Anyways to make up for this they said they would give me a brand new card that they were sending to the stores instead, an AX7970 3GBD5-2DHV3 and it comes with a completely different VRM configuration.
Wazza300 i think i may be getting a Powercolor card with the same VRM configuration as yours. How did you place your heatsinks? Also how do i order the conductive tape? I kinda threw mine out.
looks like the permanent adhesive will be permanent on these types of vrms...
conductive tape? non conductive adhesive you mean? either paste or tape you want,i used the g1
theres a pic a few pages back of how I applied the heatsinks,for the four vrm's on the right I used two of the large l shaped ones and cut one down to fit,then had them facing each other with the fins interlocked
^^ like that
vrm temps are usually 65c,only hit a max of 73c in the most few demanding games,core temps never go above 55c
EDIT: I found it easier to dip the heatsink in the paste,then stick it to the board
You know wazz i completely forgot your card had that vrm layout. You have more cooling surface with all those heatsinks than me, no wonder your temps were better. :)
why don't you just go water cooled Matt? All this mucking about with different heatsinks - just go water and know there's nothing better out there...until the 8970
or just go crossfire in june when the fancy drivers come out. Either way you'll get more performance than the extra 30mhz you'll get out of your 7970.
Or maybe you could sell your 7970 to 8pack - it's a known awesome clocker - and he could win some records with it with some LN2...
Next rig built from the ground up will be water cooling, not this one.
Haha i can't see him wanting to buy it. :D
I won't be doing things in half measures. If im going to the effort of it, it has to be done properly with proper colour co-ordination from the start and my parts will have to careful picking individually to match the colour scheme i plan. That's for my next rig not this one.
I don't want the hassle of it right now, i just want to game and clock my parts hard. (that's what she said)
water cooling needs a lot of maintainance though,with air you can fit it and forget it
That. ^^
I'm also fed up of fiddling, with what i have planned i shouldn't have to fiddle ever again once ive got things setup properly. Its slowly coming together, i hope to have all my relevant parts by the end of next week.
