Computer Beep Codes
29 Oct 2007
http://www.computerhope.com/beep.htm
Whilst the computer has successfully booted up, it is randomly making a single beep noise.
My computer is also regularly blue screening and the event viewer shows these 4 events in the last 24 hours from the source "kernel-power".
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2013-04-26T11:26:16.148425800Z" />
<EventRecordID>31845</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Sean-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">36</Data>
<Data Name="BugcheckParameter1">0x1904fb</Data>
<Data Name="BugcheckParameter2">0xfffff8800318c758</Data>
<Data Name="BugcheckParameter3">0xfffff8800318bfb0</Data>
<Data Name="BugcheckParameter4">0xfffff880012c6c59</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Could this be down to a faulty PSU? It's a 500w EarthWatts one from 2009
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail
Asus GeForce GTX 460 1024MB DirectCU GDDR5 PCI-Express Graphics Card
Geil Black Dragon 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Triple Channel (GB36GB1333C9TC)
Seagate Barracuda 7200.10 250GB SATA-II 16MB Cache - OEM (ST3250410AS)
peripherals include.
2 LCD displays
Razer Lycosa Keyboard
Razer DeathAdder
using latest bios? heres latest beta bios,you can flash back if it doesn't fix things
http://www.mediafire.com/?abb80enw0ly3hqh GA-H55M-UD2H - F12c
kernel power just means the pc shut down unexpectedly
are you stock or overclocked? you might need a touch more qpi/vtt,maybe 1.2v
if you flash the bios it will reset any overclock/bios settings so make a note beforehand
Single beep noise is normal? My BIOS make's a single beep and then passes over to the OS.
Regarding the blue screens, test your RAM with Mem-test and see if it runs stable using Prime95, do you have another PSU to use?
The computer boots fine. It will randomly make the single beep noise after Windows has loaded.
Download a bootdisk like Hiren or ultimatebootcd and run a memtest. I have seen systems in the past continously beep and that was from faulty RAM but the system still booted.
Welcome to troubleshooting hell, if you don't have a bootdisk already get one. It makes the diagnosing process much easier.
Also get a program such as WhoCrashed that will go through the error files generated by the BSOD and may be able to point you in thew directions of what is causing them.
