- 2 May 2011
- Woking
Afternoon all,
As the title states, I'm a watercooling noob and would appreciate some advice on the component's that I'm going to need.
I have, on order, a Fractal Design Arc Midi R2, which I'm incredibly excited to receive for a few reasons, one of the main ones being that it will allow me to use 2x240 rads in a midi case.
As far as parts to watercool go, I have an i5, currently overclocked to 4GHz (using a Corsair H50, which I won't be using), and 2xGTX 480s, both already having EK blocks attached with backplates (what difference does having a backplate make??).
So, I want to be able to cool these three components.
As I've already said, I want to use 2x240 rads. Would 60mm rads be unnecessarily thick? I'm bidding on one on eBay shortly, so I'll have at least one, which I guess I will use with the GPUs, and the other for my CPU (even though that's obviously overkill).
Here's where I get a bit stuck...I'm going to be reading loads of watercooling before I really get started, but would appreciate you clever people's advice on the rest of the components.
I'm thinking of getting an Alphacool Cyclone R2 because I really like the look of them, and I love the generally innovative attitude of Alphacool, so would like to use their components where possible. I think this is where experience will go a long way as I've really got no idea which pumps to buy with this, whether I need one or two, which tubing I need etc!
Any advice on this would be greatly appreciated. I'm aiming for an incredibly quiet system with fairly high performance, although I realise that I'm limited a little by the general spec of the PC.
One additional question actually: I could use 280 rads, would this also be overkill?
Thanks in advance,
dirtychinchilla
Thanks in advance,
dirtychinchilla
