Speck me plz
9 Jun 2010
Aberdeenshire
Hi guys, the noob is back for more help :p
right now Im using my MoBo Sound & some unknown brand of cheap 5.1 Speakers i picked up years ago (which are dying) so I'm looking to get some new speakers & a sound card (if recommended) for Listening to Music & Watching Movies, (for Gaming I always use my Sennheiser PC 360 headset), I also like to play the guitar through the PC (currently Im just using an adapter to plug it into my MoBo), Im also using an adapter so that I can have my Headset & Speakers plugged in at the same time (speakers are turned on/off by a remote, also I have a bad habit of using the Subwoofer as a foot stool so I need something strong without easy to adjust buttons on the front/top :p )
Thanks for taking the time to read :)
Edit:
I almost forgot price isnt really an object (but that doesn't mean to say I wanna go spending £500 tho :) )
thanks for posting (although I don't have a budget those speakers seem a little expensive, for the amount of time I would be using speakers I wouldn't really wanna go over say £100 - £150 for them)
Thanks again for posting :)
Hi david thanks for posting.
I think for the soundcard im defiantly leaning towards an ASUS (I had a Creative SB card years ago & ran into allot of problems with its drivers/support) plus my current MoBo is an ASUS Rampage IV GENE & im very happy with it :)
thanks for continuing to help guys, sorry if this is a retarded question but if I were to go for the STX card & plug in my headset would I be able to setup surround sound for the speakers through the MoBo sound inputs or would there be some kind of conflict/problems in doing that :S
You can use onboard audio as well as a sound card. I and plenty of people have always done it with no issues. You will need to swap between them in the Windows sound properties though.
