Well where to start...
I haven't upgraded anything in years as my gaming days seemed to be well and truly over. I'd never really found anything to entertain me since my old Quake days. However I've recently become just a touch enthrawled with Hawken and, surprise, surprise, my stone age PC is no longer up to the task. It is a miserable state of affairs to be in because when Quake took over my life then money was no object.
Nowadays however I have a family and am more restricted on budget.
I am looking for a graphics card up to £300. But it has to be fairly quiet as I also use the PC for work.
My Current System
Q9450 (stock speed - don't wan't to overclock much as stability is key for work)
8gb RAM
600w PSU
GTX 260
Dell 3007 30" with 2560x1600 max res
Is it worth upgrading only the graphics card or should I really consider a CPU upgrade first/soon after? Ideally I'd prefer not to as this will reduce the graphics card budget to some extent.
Will the PSU be sufficient?
What's a reasonable graphics card for £300 nowadays? Budget is not set in stone and is only a guide.
One last thing... I don't mind playing on lower texture settings as I find it usually makes a clearer display but would like to run Hawken at 2560x1600 if possible (1280x800 is a possibility).
Many thank you's
My Current System
8gb RAM
600w PSU
GTX 260
Many thank you's
