- 27 Aug 2011
I decided to do some overclocking with my 3570k after reading some of the experiences of people with the same chip.
The ASUS auto overclock used 1.325v for a 4.6Ghz overclock which I thought was quite a lot.
At first I wanted to see how low a voltage I could get away with at 4.5Ghz and the results surprised me. All temperature results are after 10 runs of standard Intel Burn Test.
I am using a custom water cooling loop with XSPC raystom CPU block.
Lowest attainable vCORE: CORE 1, CORE 2, CORE 3, CORE 4 temps
3.8Ghz (Stock speed. Stock voltage. Everything set to auto.)
AUTO VOLTAGE: 45c, 54c, 48c, 47c
4.5Ghz
1.16v: 50c, 60c, 54c, 53c
4.6Ghz
1.19v: 53c, 62c, 58c, 55c - SUCCESS!
4.7Ghz
1.23v: 57c, 65c, 62c, 59c - SUCCESS!
4.8Ghz
1.30v: 62c, 73c, 71c, 67c - SUCCESS!
4.9Ghz
1.36v: 69c, 81c, 78c, 75c - SUCCESS! (But very hot!!)
5.0Ghz (Disabled speedstep. Load-line set to extreme. PLL overvoltage enabled)
1.40v: 78c, 92c, 91c, 87c - SUCCESS (But god dammit that is toasty!)
Conclusion
So it looks like somewhere between 4.5 - 4.7Ghz is the sweet spot. Going from 3.8Ghz to 4.7Ghz means about a 10c average increase in temps across the cores. Going from 4.7Ghz to 5Ghz means an average increase of almost 30c across the cores!!
I am so tempted to de-lid my IHS and get some proper thermal paste on the die. I heard it drops temps by as much as 10-15c but I am skeptical.
Hope this helps some people with their expectations when trying to overclock their 3570k.
Thanks for reading
4.5Ghz
4.6Ghz
4.7Ghz
4.8Ghz
4.9Ghz
Conclusion
Thanks for reading
