New build - Ordering today - What you think?
Slightly over your max budget, but the 7870 XT will OC to 7950 stock speeds.
Also the ram you chose is not available.
YOUR BASKET
1 x Sapphire HD 7870 XT rev2.0 2048MB GDDR5 PCI-Express Graphics Card £209.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £189.95
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £85.99
1 x Corsair Builder Series CX 500W V2 '80 Plus Bronze' Power Supply (CP-9020047-UK) £49.99
1 x GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC) £47.99
1 x **B Grade** Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (S (HD-257-SE) £45
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x Thermalright Macho 120 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
Total : £706.88 (includes shipping : £12.50).
Or just a 7850 with an ssd.
YOUR BASKET
1 x **B Grade** MSI HD 7850 OC 1024MB GDDR5 PCI-Express Graphics Cards w/ FARCRY3, Nexuiz & Sleeping Dogs PC Games £119.99
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £89.99
Total : £706.87 (includes shipping : £12.50).
there's no real easy way to check other than asking people with similar setups :p
ram looks fairly small so i wouldn't imagine there'd be a problem.
Okey dokey! I know I cut it close in my previus rig,a nd I didn't even consider it this time.
Should get it ordered tonight! Cheers all!
What ram have you decided on?
As I mentioned in an earlier post the Patriot ram you chose in your spec is not available.
YOUR BASKET
YOUR BASKET
The bottom spec 7850 is only a 1GB one, nowadays you really need more than 1Gb VRam. A freind has SLI 560ti 1Gb's and they have the power to push most games at max, but then hit ram limits quickly. A 7850 has the power to fill that 1Gb quickly with modern games.
Actually, I don't think that the black mamba will be supported on the motherboard.
4x DDR3 1600/1333/1066 MHz memory modules
That is for the motherboard i am picking
should have been the "B" grade GB version. Not to worry. :D
Looks good!
Don't get me started on budgets though, I started at £500 and ended up spending £741!
