UK Electrical Products in UK?
29 Jul 2011
Near Northants / MK
Hey guys,
How does one source a transformer(?) to use GHD Straighteners(dont know if this is relevant) in the US? I remember a thread about a guy needing to transform a US Product into a UK Socket however I don't believe you need one for the US however best to check...
The person in question also wants to charge an iPhone, I'm guessing its as simple as buying a USB to US Socket adapter or buying one from a US apple store?
Check to see if the device is rated for 120V first of all, you may not need to buy a transformer, just an adapter.
If it's only rated for 240V than you'll need a transformer.
Er. Which way are you going, UK->US or US->UK
UK > US
If it is 240V how could one source a transformer and how much are they? The person in question is only going for a couple of weeks and doesn't really want to buy a new set of GHD's as to my understanding they are not cheap.
You'll struggle to get a cheap step down transformer that will handle the wattage pulled by a pair of straighteners I would imagine.
I'm pretty sure GHD's are 120/240v though so should be fine with just a plug adaptor.
edit: after a quick google they are indeed universal voltage.
From my (limited) experience i wouldn't have thought they were portable as the one i used to have was huge.
I'd be surprised if the GHD's weren't able to operate on 120V though. I think most things like that are.
My O/H has about 3 pairs of GHD straighteners, hers are all certainly 120v capable, she spends a lot of time in the US.
GHD straighteners actually use a US plug - I had to replace the cable on the mrs' one a couple of weeks ago. They just use a UK plug adapter.
I'm still awaiting an answer on what V they are :/
Don't have them with me so it's hard to check info right away.
Thanks guys :)
GHD Website said:
The ghd IV stylers and ghd Gold Series stylers have universal voltage so that you can use your styler in any country using a travel adaptor.
Model 3 and 3.1b stylers only work in countries where 220-240V power supply is available. We recommend you check the voltage available in your destination before you travel.
So 'GHD' isn't just a name for a special temp or something? It's a manufacturer? I'll stick with getting it checked on the Voltage.
Nope they're a manufacturer and God forbid you try and buy a woman any other make of straighteners! :D
Yeah I did a Google search, £100? I guess this is women becoming sheep? Having to buy them because of the name?
That, and to be fair they are apparently very good and come with a lifetime guarantee.
So considering some days my gf never seems to stop straightening her hair it's not a bad deal.
Meh, I guess that's not so bad... Still wouldn't catch me buying them :P
Just realised the thread title, I'm blaming iOS
So, how would one access this? I'm nowhere close to them and have no idea how they look :D
