Quick Naked Ivy mount test
6 Feb 2013
Did a quick before and after test of the Naked Ivy mount for EK Supremecy block.
Both tests done with same bios settings. 3770k @ 4.7, 1.4v to generate some heat, Ulta llc.
EK Supremecy, de-lidded 3770k with Liquid Pro on IHS & chip:
EK Supremecy with Naked Ivy mount, Liquid Pro:
Not quite the result I was expecting but I guess every little counts :rolleyes:
Not what I would have expected either, 1c maybe 2c on average, but looks a better differential across the four cores.
8 seconds per test isn't really very thorough, in the future you should select custom setting and assign 75% of total memory. ;)
This exactly, nice result but if your going to the effort at least test it thoroughly.
Yeah, with hindsight should have done a more thorough test .
I was impatient to fit the Naked Ivy and expected even a short IBT run to show a much bigger difference than it actually did.
