Budget Machine :)
8 Oct 2003
Glasgow
Hey Guys,
Will the following all work together, I'm pretty skint so bare this in mind if anything needs to change. I'm planning on adding a better GPU once I get some more money.
Thanks Kevin.
AMD A10-5800K Black Edition 3.80GHz
Gigabyte F2A85X-D3H AMD A85X Chipset
Patriot Viper "Black Mamba" Generation 3 8GB
Imp MicroATX Tower Case (500w PSU)
Hey Guys,
Thanks Kevin.
Looks good, all apart from the Psu.
What is your max. budget?
£3 extra for a board which is full size and can host a few extra things if needs be, seems reasonable. Plus is looks aesthetically pleasing in the flesh.
I think I would go for performance over aesthetics when on a tight budget. Besides, you are not likely to see much with the side panel on.:p :D
You make a fair argument, I just think that board looks lavely, would be helpful with a window!
What is this PC for, just a standard PC or some light gaming involved?
Not sure what the main use will be. The OP did say he was going to add a Gpu when funds allow, so I would assume gaming.
