Good air flow advice
I have an xblade case.. quite old and poor cable management etc...
I have an aegir sd128264 heatsink quite large with a 120mm fan
the side fan on the xblade case is a tiny fan which just about shuts but means the fan blowing directly next to heatsink fan which is blowing air through the heatsink fins.
I ahve a front fan as well which looks to be blowing air into the case too.
i ahve just brought anotehr 2 120mm fans (one for heatsink) and one for back of the case.. but not sure whether I should a, use both and b, if I do what to do with them
i assume id want the 120mm to join the other 120mm fan for heatsink blowing air through the fins, but then it menas its right next to the other 120mm fan on the rear (which I dont know whether should be exhaust or not)....
my graphics card is being rma'd as its 100c but want to make sure its not due to airflow.
psu isnt modular either, and no cable control on case
