Morning folks! Hope you're having enjoying your Bank Holiday Monday - and to hopefully make it a little more enjoyable we've got the Zowie EC2 eVo mouse & the Asus RT-N12E router on offer today.
Zowie EC2 eVo 2300 DPI Pro-Gaming Mouse - White - Only £47.99 inc. VAT
1.5 mm lift-off distance - one of the lowest on the market to date
One of the primary features of the ZOWIE EC-series is the lift-off distance. ZOWIE EC-series has made it possible to create one of the lowest lift-off distance currently available in any optical mouse on the market - 1.5 mm.
1,000Hz USB Report Rate - plug and play with 1.000Hz
Most optical mice are 125Hz which can be artificially raised to 500 – 1,000Hz through driver installations. The ZOWIE EC mice were the first optical mice to introduce 1,000 Hz from standard, without any installation of drivers.
Improved mouse wheel
The mouse use an optical encoder instead of the cheaper traditional mechanical system and added a new optimized rolling system developed by ZOWIE, which ensures that the mouse wheel is the most durable and precise mouse wheel on the market today.
DPI-adjustment
Adjusting DPI on the fly is not really an innovative feature, but ZOWIE decided to put it on the mouse anyway, as it's important for a gamer to be able to optimize the settings to create the perfect feeling when playing.
DID YOU KNOW?
That you can change the Hz of the EC-mice without any software?
- 100% stable optical mouse developed by HeatoN
- Ergonomic designed right-hand gaming mouse
- 1.5mm lift-off distance
- Improved mouse wheel system
- Easily change to 1000, 500 or 125 Hz
- Plug and play! No drivers or software
- DPI adjustment: 450/1150/2300
- Operating system: Win2000/XP/Vista/7, Mac OS X V10.2 after
- Frames Per Second: 6,400
- USB report rate: 1000/500/125 Hz
- Dimensions: 120 x 40 x 58-65 mm
ONLY £47.99 inc. VAT
CLICK HERE TO ORDER NOW
_
Asus RT-N12E 300Mbps Black Diamond Eco Series Wireless Router - Only £21.59 inc. VAT
Save the planet and your pocket
Compared with generic Wireless-N routers, ASUS ECO-WiFi CPU reduces 72%* of energy consumption and utility cost
Extended Network Coverage
The RT-N12E features a 5dBi high-gain antenna that boosts the wireless signal, thereby extending coverage range.
Network Map-Manual Free Management
Straight-forward design to help users to:
Display the whole network status and clearly provide WAN/LAN status
Securely connect to your wireless network and prevent intruders from using it
Manage your network in minutes
Try our EZ UI software
• 300 Mbps high speed
• Plug-n-surf CD free installation
• External 5dBi antenna for better coverage
• Power saving: consumes less power during stand by mode
• Support EZ WPS connection
Network Standard: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3, IEEE 802.3u, IPv4
Data Rate 802.11b : 1, 2, 5.5, 11Mbps
802.11g : 6,9,12,18,24,36,48,54Mbps
802.11n : up to 300Mbps
Antenna: External dBi antenna x 2
*Antenna type will differ according to local regulations and requirement in each country
Operating Frequency: 2.4GHz
Encryption: 64-bit WEP, 128-bit WEP, WPA2-PSK, WPA-PSK, WPA-Enterprise, WPA2-Enterprise, Radius with 802.1x, WPS support
Firewall & Access Control: Firewall: NAT and SPI (Stateful Packet Inspection)
Filtering: Port, IP packet, URL Keyword, MAC address
Management: DHCP
VPN Support: IPSec Pass-Throuth
PPTP Pass-Through
L2TP Pass-Through
WAN Connection Type: Internet connection type : Automatic IP, Static IP, PPPoE(MPPE supported), PPTP, L2TP
Utilities: Device Discovery
Firware Restore
Setup Utility
Ports: 1 x RJ45 for 10/100 BaseT for WAN, 4 x RJ45 for 10/100 BaseT for WAN
Button: WPS Button, Reset Button, Power Button
LED Indicator: PWR x 1, LAN x 4, WAN x 1
Power Supply: AC Input : 110V~240V(50~60Hz)
DC Output : 12 V with max. 0.5 A current
Environmental Operating Temperature: 0 °C to 45 °C ( °F to ºF)
Storage Temperature: -20 ° to 70 ° C ( °F to °F)
Operating Humidity: 10 % to 90 % (Non-condensing)
Storage Humidity: 5 % to 90 % (Non-condensing)
Dimensions: 168 x 124 x 30 mm (LxWxH)
Weight: 210 g
ONLY £21.59 inc. VAT
DPI-adjustment
DID YOU KNOW?
_
Management: DHCP
PPTP Pass-Through
L2TP Pass-Through
Firware Restore
Setup Utility
Weight: 210 g
Simply cus the BT one at home is AWFUL.
