heads up free £22 psn funds
Let's look at it this way..
The supply of codes are limited. Sony will have projected the costs of all the codes being handed out, etc. The only problem is that they're going to run down quicker. It's really no loss to Sony if you add it all up. The only hurting thing would be that as the money adds up for one person, they can buy £40-50 releases. Whereas if you restrict £22 per person, the consumer has to find the remaining £18. So I guess there will be losses.
My two cents.
My two cents.
a guy on here said he had done it 6 times, probably even more by now.
say other people are also doing his method, you could see how one guy could easily rack up over £1000 in a day if he wanted to.
i bet somebody out there probably has too, i looked into the emulator, but it looked like a lot of hassle with setting up new google accounts or something in order to do it.
I'm pretty certain someone said that it's only one code per account, so you would just end up with a load of psn accounts with £22 on them.
You don't need a new google account each time. You never need to log into a google account.
i have just thought of a method of turning the credit into hard cash, not willing to discuss it though because someone could quite easily make £100+ per hour doing it in cash.
Is the method just to sell the codes (which can be activated on any PSN account) for cash? If it's any more complex than that, then you're wasting your time.
I can see that causing big problems though if (when?) Sony block these codes.
it was to use the credit to buy packs on fifa ultimate team.
packs = players
players = coins
100K coins can be sold for £10 usually on ebay.
basically even if they blocked your account you could still use your ultimate team account to sell the coins on.
fugly me backwards... I can't get it to work.. lol
the phone is rooted.. but every time I change it.. reboot.. it changes back..
If it's a physical device then just edit the build.prop manually.
Edit: Looks like they finally cottoned onto the abuse of the system.
tried that...
I think I know why it ain't working... I think someone flashed it with a custom firmware on it to unlock the phone from the provider. As looking at the firmwares to return the phone back to normal... the name of one firmware kept popping up.
packs = players
players = coins
Thought about that. Bit crap though.
How?
