7 May 2013 at 14:26 #1 tribz tribz Soldato Joined 4 Mar 2008 Posts 2,648 The last time I used VMWare server, the free one was version 2. Which is the equivalent nowadays? I'd like to import a couple of Hyper V test systems into it but the standalone convertor wont importing into anything version 3 or less.
7 May 2013 at 14:33 #2 m4cc45 m4cc45 Soldato Joined 10 Mar 2003 Posts 6,878 http://www.vmware.com/products/vsphere-hypervisor/overview.html M.
7 May 2013 at 14:34 #3 tribz tribz Soldato OP Joined 4 Mar 2008 Posts 2,648 Isnt that bare metal though? Is there one that runs on a Windows host?
7 May 2013 at 14:49 #4 RSR RSR Soldato Joined 17 Aug 2006 Posts 10,438 tribz said: Isnt that bare metal though? Is there one that runs on a Windows host? Click to expand... VMware Server is EOL now. The only hypervisors which runs on Windows now are VMware Player and Workstation.
7 May 2013 at 14:50 #5 jameshurrell jameshurrell Associate Joined 1 Jan 2013 Posts 178 I think you need VMWare Player - it installs on a PC just like any other software and you run the VMs inside it. http://www.vmware.com/products/player/overview.html
7 May 2013 at 15:39 #6 tribz tribz Soldato OP Joined 4 Mar 2008 Posts 2,648 Thanks for the replies. I'll check out the player.
17 May 2013 at 20:30 #7 gavind gavind Associate Joined 30 Mar 2013 Posts 52 By the way, how much memory should we have set up? Last one I tried, 4GB is not enough and we will experience slowness.
