- 18 Apr 2003
- England
I recently purchased from ocuk an Asus vs278q-p gaming monitor which I got to use with a noisy gaming pc that's in another room.
To span the distance between the pc & monitor I'm using a 10m HDMI cable of which the monitor can also use for sound if needed. The distance is actually 8m but I can't find an 8m cable.
The issue I have is the display keeps cutting out for a few seconds at a time which becomes a lot worse when using HDMI audio too: like as soon as a youtube video starts to play the display cuts out.
The same HDMI cable when plugged in the tv has no issues at all & the monitor is fine when a short 1.5m HDMI cable is used.
As the monitor is ok with a normal sized cable I presume it's not faulty nor would an exchange monitor be any different? Plus it has no dodgy pixels so I'm loathed to try swap it.
Obviously this type or range of monitors has issues with the HDMI input.
I've tried 3 different HDMI cables & HDMI / dvi output on the nVidia 480soc.
Now the monitor has stopped cutting out, instead it now has thousands of green twinkling pixels.
Will a HDMI repeater help? I've seen them quite cheap at £8 or would a powered version be better?
Thanks
Thanks
