7990/Ares II Vs Ttian/690
Caporegime
12 Jul 2007
United Kingdom
Drivers Used
Nvidia GeForce / ION Driver Release 320.20
AMD Catalyst 13.5
Results
gamgpu said:
GEFORCE GTX TITAN - it's the fastest single-chip solution for today, although in most cases inferior to his brother GEFORCE GTX 690. And as we have mentioned before - GEFORCE GTX TITAN is a card game for the next generation, which is especially noticeable when using extreme quality settings.
GEFORCE GTX 690 - this is the fastest solution from NVIDIA to date, with low power consumption and excellent acoustics. GEFORCE GTX 690 allows you to play all modern games on almost all quality settings, the only drawback of this card is the tandem of SLI and a rather meager amount of video memory for ultra-high resolutions.
Radeon HD 7990 - at the moment it is the fastest graphics solution available, which in most cases is faster GEFORCE GTX 690 and allows you to play the game in all modes and all quality settings. The only drawback may not always be well-organized work and AMD CrossFireX delay output frames, which in some games very much appears that gives some discomfort ...
ASUS ARES II - is a champion who is unparalleled both in performance and price. This is a very specific graphics solution that is very problematic to buy, even with the availability of funds. This card has the same advantages and disadvantages as the Radeon HD 7990.
Source
http://gamegpu.ru/test-video-cards/titany-i-olimpijtsy-test-gpu.html
Im surprised nvidia did so well tbh, especially the 690, The 7990 would have been a brilliant card a year ago. Right now there really is no point buying any top end cards as they are either - Too pricey or not worth upgrading from what we already have.
Drivers Used
AMD Catalyst 13.5
I have been looking at the GTX 690 results and they don't look right. The rig my GTX 690s live in is almost identical to what the reviewers were using so I did a few runs on the Futuremark benches using the same settings.
Drivers 320.00
CPU 3960X @ 4.9
Memory 16gbs @2400mhz
3dmark Firestrike Extreme GPU score
Their GTX 690 @stock 5398
My GTX 690 @stock 5850
http://www.3dmark.com/fs/443769
Their GTX 690 OC 5869
My GTX 690 OC 7038
http://www.3dmark.com/fs/443836
3dmark11 Extreme GPU score
Their GTX 690 @stock 5585
My GTX 690 @stock 5783
http://www.3dmark.com/3dm11/6547170
Their GTX 690 OC 6045
My GTX 690 OC 6954
http://www.3dmark.com/3dm11/6547329
The overclocked figures don't really mean much, as they may have had a bad clocker but the stock figures do.
My GTX 690 I used is celebrating it's 1st birthday this month, so if anyone reads this can they sing happy birthday.:D:)
Maybe your 690 boost clocks further than theirs. I checked their AMD results against my own using a slower cpu and from around the web and they appear to be a few hundred points down below what i am seeing as well so it looks to be a thing affecting all cards in this bench unfortunately.
on their other Titan review I found that I was getting the same or higher scores than them in firestrike on much lower CPU and GPU clock settings than they claimed to be running as well
I will have a look at their Titan figures, I think I have got one somewhere.:D
Suppose not coming dead last 12 out of 16 times would be a slight comfort.
Tbh when neither card can achieve a playable frame rate in a test its not that important which one is on the bottom, in the two 3DMARK tests they traded the bottom position and in the one shooter game where they achieved playable FPS they were dead tied, add to that the 680 won in Shogun 2 (a turn based strategy game so "playable" FPS is lower) I don't think that the 680 being on the bottom in a load of tests where the 7970 wasn't playable either is that important.
Just noticed they appear to be using newer drivers than Kap Nvidia GeForce / ION Driver Release 320.20 vs 320.00. That could explain some difference i suppose. Its hard to say really especially when things like different boost clocks skew results.
Maybe a piad off AMD review site. Maybe id some users with similiar systems can do the benchies with links we can rule that out or not.
Few hundred points missing from my 7970 ghz results vs theirs so i suggest they should start asking AMD for more money in that case. :rolleyes:
