Just Put a Deposit on This
I get confused with the suspension as on some the Msport suspension is a delete option. But then it comes standard with sport suspension which is a level above normal but isn't Msport?
Thanks; I didn't know that about the DAB. It's not really an essential for me, more of a "would be nice to have". Main thing is the USB connectivity.
I'll be going over the car on Saturday. There are some things I want that are not listed on the BMW website; namely:
Wind deflector
Xenon headlights (although I think these are standard)
M Sport adjustable suspension
Extended Storage
The only thing it doesn't have that I really wanted was comfort access, but again, I can live without it. However if it doesn't come with a wind deflector I will insist they throw it in.
Xenons are standard. The wind deflector isn't I don't think but it does make a big difference.
Comfort access is quite nice (mine does have it) but it's really not enough a deal break IMO. Does yours have iPod integration? That's the once big thing that annoys me about mine.
[TW]Fox;24249690 said:
People think white looks good whereas in reality good cars look good despite ruining them by not painting them :p
More interesting than boring silver though and looks nice with black wheels
It say's it comes with a connectivity package so I'm assuming it does. As long as I can plug a USB device in I'll be happy as I don't have an iPhone with music, just a ipod for the gym.
Same here, I've read somewhere that it comes with adaptive suspension as standard, but I don't think this is true. There are 3 modes - comfort, sport and sport+. If you have M Sport adaptive suspension it adjusts whenever you change the driving mode. If you don't have the M Sport adaptive suspension then it just adjusts the steering and throttle response.
Yeah mine doesn't have the USB :(
I didn't have it on my M3 either, but was going to retrofit it. I think it was around £400 for parts and extra for labour. It was complicated but it can be done. That was for the older CCC iDrive system though.
You can still upload songs onto the 12gb HDD though.
Yeah I upload them but it's just annoying to have to do it versus having proper iPod integration.
Extended storage is extremely crap mate, I'd not worry too much about it vs the other stuff there. It's nets behind the seats (virtually unusable unless you're a midget - I'm only 5'7 and I can't get hardly anything behind them), a net in the drivers side footwell big enough to fit a can and some rubber straps in the boot - except the straps are attached to the flimsy battery cover piece of cardboard-like material so it's not exactly fixed. Wind deflector is a mesh type and I haven't bothered putting it in this year. It's OK but not exactly amazing.
USB was an option until... 2010? Then became standard at some point. It switched over when they switched the electronics over inside one of the modules - might have been the combox? Combox does more than standard USB, it only required one cable, did album art etc... Standard USB works a treat though, I just have a standard USB drive attached although it's pretty slow.
Regarding msport etc... just to be clear:
msports come with msport suspension (harder, lower) but could be deleted as build option
IS model comes with adaptive suspension linked to norm/sport/sport+
adaptive is an option for all cars additionally.
It comes as standard with M Sport suspension which you can delete for free.
Nice one cheers :) Thats good to know about the USB function. The car was registered in Oct 2010 but could have been built before the change over. Is there any way to tell?
Google tells me week 35 which is end of August. Combox allows bluetooth A2DP streaming which I don't have so I can't tell you the exact test but I'd connect a phone via standard BT then enable A2DP in <phone music player of choice> and give it a whirl.
6FL is the code for USB standalone, I think the combox code is 6VC from googling it. I think these are likely to be mutually exclusive. You can grab a buildsheet if you have the VIN of the car using this method.
Awesome info. Going to get the VIN number off the dealer tomorrow as the warranty isn't bringing anything up (maybe due to the car still being under manufacturers warranty still).
To follow on; I used this website instead as the BMW link wasn't showing anything: http://www.rubmw.ru/vincode/eng/
The car has the following spec:
PHP:
**Vehicle information
*Type	*Value
*VIN	*WBALM72090E410898
*Type code	*LM72
*Type	*Z4 35I (EUR)
*E series	*E89 ()
*Series	*Z
*Type	*ROADST
*Steering	*RL
*Doors	*2
*Engine	*N54
*Displacement	*3.00
*Power	*225
*Drive	*HECK
*Transmission	*MECH
*Colour	*BLACK SAPPHIRE METALLIC (475)
*Upholstery	*LEDER KANSAS/D1 KORALLROT (LYD1)
*Prod.date	*2010-09-10
**Options
Code	*Description (interface)	*Description (EPC)
S1CAA	*SELEKTION COP RELEVANTER FAHRZEUGE	*Selection of COP relevant vehicles
S1CBA	*CO2 UMFANG	*CO2 equipment
S1CDA	*BRAKE ENERGY REGENERATION	*Brake Energy Regeneration
S216A	*SERVOTRONIC	*HYDRO STEERING-SERVOTRONIC
S230A	*EU SPEZIFISCHE ZUSATZUMFAENGE	*Extra package, EU-speciifc
S249A	*MULITFUNKTION FUER LENKRAD	*Multifunction f steering wheel
S2MUA	*M LM RAEDER STERNSPEICHE 325 M/MB	*BMW LA wheel, M star spoke 325
S2PAA	*RADSCHRAUBENSICHERUNG	*Wheel bolt locks
S2TCA	*SPORTGETRIEBE MIT DOPPELKUPPLUNG	*Sport gearbox with twin clutch
S302A	*ALARMANLAGE	*Alarm system
S313A	*AUSSENSPIEGELPAKET	*Fold-in outside mirror
P337A	*M SPORTPAKET	*M Sports package
S423A	*FUSSMATTEN IN VELOURS	*Floor mats velours
S428A	*WARNDREIECK	*Warning triangle and first aid kit
S431A	*INNENSPIEGEL,AUTOMATISCH ABBLENDEND	*Interior mirror with automatic-dip
S441A	*RAUCHERPAKET	*Smoker package
S459A	*SITZVERSTELLUNG, ELEKTR.MIT MEMORY	*Seat adjustment, electric, with memory
S470A	*KINDERSITZBEFESTIGUNG ISOFIX	*Isofix-System
S481A	*SPORTSITZE FUER FAHRER/BEIFAHRER	*Sports seat
S494A	*SITZHEIZUNG FUER FAHRER/BEIFAHRER	*Seat heating driver/passenger
S4MWA	*INTERIEURL. ALUMINIUM CARBON SHADOW	*Interior strips, Aluminium Carbon Shadow
S502A	*SCHEINWERFER-WASCHANLAGE	*Headlight cleaning system
S508A	*PARK DISTANCE CONTROL (PDC)	*Park Distance Control (PDC)
S521A	*REGENSENSOR	*Rain sensor
S534A	*KLIMAAUTOMATIK	*Automatic air conditioning
S544A	*GESCHWINDIGKEITSREGEL. MIT BREMSF.	*Cruise control with brake function
S563A	*LICHTPAKET	*Light package
S609A	*NAVIGATIONSSYSTEM PROFESSIONAL	*Navigation system Professional
S612A	*BMW ASSIST	*BMW Assist
S615A	*ERWEITERTE BMW ONLINE INFORMATION	*Extended BMW Online Information
S616A	*BMW ONLINE	*BMW Online
S633A	*HANDY VORB. BUSINESS/BLUETOOTH-SCH.	*Preparation, mobile phone, Business
S694A	*CD-WECHSLER VORBEREITUNG	*Provisions for BMW 6 CD changer
S698A	*AREA-CODE 2	*Area-Code 2 for DVD
S6AAA	*BMW TELESERVICES	*BMW TeleServices
S6ABA	*STEUERUNG TELESERVICES	*Control, Teleservices
S6FLA	*USB-AUDIO-SCHNITTSTELLE	*USB/audio interface
S6NFA	*MUSIC-SCHNITTSTELLE FUER SMARTPHONE	*Music interface for Smartphone
S6VCA	*STEUERUNG COMBOX	*Control, Combox
S704A	*M SPORTFAHRWERK	*M Sports suspension
S715A	*M AERODYNAMIKPAKET	*M Aerodynamics package
S775A	*INDIVIDUAL DACHHIMMEL ANTHRAZIT	*Headlining anthracite
P7HPA	*CONNECTIVITY PAKET II	*Connectivity Package II
S7XAA	*M LEDERLENK.+SCHALTWIP.+MULTIF.	*M leather st.wheel+shiftpaddle+multif.
L812A	*ENGLAND/IRLAND AUSFUEHRUNG	*National version England / Ireland
S850A	*ZUSAETZL. TANKFUELLUNG EXPORT	*Additional Export tank filling
S863A	*SERVICE KONTAKT-FLYER EUROPA	*Dealer List Europe
S877A	*UEBERKREUZBEDIENUNG ENTFALL	*Omission of non-combined operation
S880A	*ENGLISCH / BORDLITERATUR	*On-board literature, English
S8KAA	*OELWARTUNGSINT. 30.000KM/24MONATE	*Dummy-SALAPA
S8S2A	*KODIERUNG ALARMSIGNAL	*Coding, alarm signal
S8S3A	*AUTOM. VERRIEGELUNG BEIM ANFAHREN	*Automatic locking during starting
S8SCA	*LAENDERSPEZ. TELESERVICEFREISCH.	*Telematics access request,country-spec.
S8SMA	*FAHRGESTELLNUMMER,V.AUSSEN SICHTBAR	*Car ident. number visible from outside
S8SPA	*COP STEUERUNG	*Control unit COP
S8TLA	*TAGFAHRLICHT FRONT UND HECK AKTIV	*Dummy-SALAPA
S8TNA	*TAGFAHRLICHT UEBER LICHTMENUE EINST	*Dummy-SALAPA
**Standard equipment
S853A	*SPRACHVERSION ENGLISCH	*Language version, English
Very pleased it has the combox. Shame theres no wind deflector, will ask them to chuck one in; it can't cost them too much. No mention of xenon lights either.
Wind deflector doesn't come on the build list. I have one and it's not on mine so I'd imagine it's just a dealer thrown in thing. When/IF you get the car you can sign up to the BMW online system and get your phone registered so you can remote unlock it etc... it should have some time left on it for you (after 3 years from factory they charge).
If you want some things to argue over with the dealer (I stress, the car is fine but incase you need counter items) you could mention that maps are out of date, it has the base audio (a few people are unhappy about the volume with top down/full pelt) and it doesn't have DAB so as it's not the perfect match for you, you'd like the wind deflector thrown in and fitted (it requires some re-assembly of the roll hoops).
Thanks for your help Myshra; I'll certainly push for the wind deflector and BMW online registration, and if they put up no resistance maybe the map update!
One more question guys; what do BMW have to do in order to prevent thieves from stealing the car via key coding and using the ODB port, like so many others have been stolen recently? They said to me something can be done but they didn't elaborate.
