[Damien];24251799 said:There's no strava segment set for it but I had a look on google street view (link). That's a pretty respectable hill tbh. If you keep attacking it on every commute you'll get better at climbing in no time.
Aye, I couldn't find it on Strava. That does look pretty serious from Google Maps, though. Pretty short, so I guess the trick is to push and then just keep going at the top. Make sure you're in a low enough gear going up and then change up when it flattens out but don't go crazy.
[Damien] said:I've modified my commute to take in this hill on my way home. It's not the steepest in the world but it gets the heart pumping towards the top.
Aye, it's a good hill that. I might pop out and do that one this evening. You need to get to grips with the Mosley Common Road climb as well - I'm still a couple of seconds ahead of you on that one
I thought i was the administrator, but i cant see any way to accept new members.
