Strolled into this thread a little late
100%+ scaling doesn't often happen, on 13.5 with bf3 we are approaching it though, 150fps avg at 1010mhz ultra pre set, sits around 70-80 fps on a single card - 1080 testing.
3dmark11 scales at around 80-90%, looking around 9000 stock single and 16-1700 on gpu scores.
Can easy try some of the other benches later, though some of those single to dual scores do seem a little off. I really wish in bench comparisons they would list the stock boost clocks of cards, makes the whole thing pointless otherwise.
Finally a friendly face!
Well google chrome translate is not working on that website at the moment for some reason but here is a list of the clock speeds.
Radeon HD 7970GE тестировалась на стоковых частотах и с разгоном Radeon HD 7970GE OC - по ядру 1160 МГц и по памяти 7160 МГц
Radeon HD 7990 тестировалась на стоковых частотах и с разгоном Radeon HD 7990 OC - по ядру 1100 МГц и по памяти 6500 МГц
ASUS ARES II тестировалась на стоковых частотах и с разгоном ASUS ARES II OC - по ядру 1200 МГц и по памяти 7200 МГц
GeForce GTX 680 тестировалась на стоковых частотах и с разгоном GeForce GTX 680 OC - по ядру 1150 МГц и по памяти 7000 МГц
GeForce GTX 690 тестировалась на стоковых частотах и с разгоном GeForce GTX 690 OC - по ядру 1020 МГц и по памяти 7000 МГц
GEFORCE GTX TITAN тестировалась на стоковых частотах и с разгоном GEFORCE GTX TITAN OC - по ядру 1080~1180 МГц и по памяти 6700 МГц
I don't think it also helps that they appear to be using a Nvidia beta driver which might have been pulled 320.20. Either that or its just a typo but i have found many references to it when searching google.
