Will this do for a few years?
1 Apr 2013
So I've been here twice already with questions about a PC and have raised my budget from £400 to £670. I wanna know if this PC, (i'm not looking to change anything) will do me for a long time.
Specs:
ASRock Extreme 4 Z77 Motherboard
i5 3570k Ivybridge Processor
Blue Corsair Vengeance 8GB Ram
Asus HD 7870 2GB DirectCUII Graphics Card
Zalman Z9 Plus Case
Corsair CX500 80+ Bronze Power Supply
Corsair H60 Liquid Cooling
Games I play:
Battlefield
Arma
etc
The PC will serve you quite well for a couple years, but i'd still change a couple things and take into consideration that Haswell will be released soon and can add that extra bit of future proofing on a new socket!
I honestly don't have the money to buy an i7 haha, otherwise I would
I also have a harddrive already, so it's all good
I think your a little muddled up, Haswell is the new 1150 socket (4xxx) chipset compared to the current 1155 Ivybridge (3xxx) chipset. It's released in June and will open your options to that socket instead of buying straight into a about to be dead socket.
Intel don't future proof, but i'd rather go 1150 at this stage! :p
I was planning on buying the AMD but I read/watched a lot of benchmarks etc and Intel seems to do better. I'd rather have intel anyway because it's literally what I've used since I got my first PC. The PC I have now is an Intel Quad Core and it's served me well since around late 2008 so it's just a personal preferance for me.
For gaming the 3570K destroys the 8350, so much so that it is ridiculous. I would expect the upcoming i5 4670K to humiliate it even further :D
Sure the i5 is more, but for a gaming machine, AMD is definitely not the way to go at this point.
I do hope AMD catch up with gaming performance soon though. I wouldn't mind having an AMD machine next time 'round if they do.
Also as a side note, the 8350 really isn't worth the extra over the 8320 IMO, which is £114, when you take into consideration that there is 200MHz per core difference to the boosted speed, and both chips will overclock. :p
