**GAINWARD RETURNS TO OcUK WITH SPECIAL TERMS ONLY FOR OcUK CUSTOMERS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Having dealt with Gainward for over 10 years and having strong ties with them, we've struck up a deal exclusively between OcUK and Gainward:-
  • [*]You can remove cooler without voiding warranty
    [*]48hr Premium RMA service provided by OcUK for Gainward Product
    [*]Latest products always first and most allocation at OcUK
    [*]Discounts available too traders, call our B2B Team for a volume quote
    [*]NVIDIA Game promotions included with Gainward cards for consumers
Here are the products were offering right now:-
Gainward GeForce GTX Titan 6144MB GDDR5 PCI-Express Graphics Card @ £827.99 inc VAT
The worlds most powerful single GPU graphics card!
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Was [£959.99] Inc. VAT
Only £827.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 690 4096MB PCI-Express GDDR5 Graphics Card @ £799.99 inc VAT
This is NVIDIA's latest GTX 690 which is a graphics card based on two full fat GTX 680's GPU's on a single PCB card. The cores are slightly clocked down too 915MHz with a boost clock of up too 1019MHz with memory clock speed at an impressive 6008MHz.
The GTX 690 offers GTX 680 SLi performance in a single lower power consumption product, with a maximum TDP of 300W, is more or less half that of the previous generation GTX 590. If you demand the absolute best and want some serious horsepower for your gaming requirements, then look no further than GTX 690.
While power efficiency is important to high-performance graphics cards, it becomes critical when building dual-GPU graphics cards. Here, two GPUs must vie for a finite amount of power, cooling, and board space. And it is here that Kepler shines the most.
The new GeForce GTX 690 is NVIDIA's flagship graphics card. Powered by two Kepler GPUs, it’s both a record setter in 3D performance and incredibly power efficient. In fact, the GeForce GTX 690’s performance is almost identical to a pair of GeForce GTX 680s in SLI, but with significantly reduced power and noise.
Not content with delivering only raw performance, our engineers went a step further. From Ferrari's F12 Berlinetta to the B&W's Nautilus loudspeaker, the flagship of any product category is invariably as much about form as it is about function. With the GeForce GTX 690, our engineers and industrial designers set out to create a new visual aesthetic to express the raw, uncompromising power of a dual-GPU Kepler graphics card.
The industrial design of the GeForce GTX 690 is a direct reflection of what lies beneath the cover: two Kepler GPUs, tremendous graphics horsepower, and a product of exceptional longevity. Visually, the design draws parallels to an F1 engine block with its raw metal look and exposed fin stacks.
The card's front plate is composed of two different materials. The exterior frame is made of cast aluminum with trivalent chromium plating, giving the board a durable, matte finish. The central fan housing is created from injection molded magnesium alloy. Magnesium alloys are used throughout the automotive and aerospace industry (including the engines of the Bugatti Veyron and F-22 Raptor) for their light weight, heat dissipation, and acoustic dampening properties. To create the intricate geometries required for the fan housing, we used a form of injection molding called thixomolding, in which liquid magnesium alloy is injected into a mold. This allows us to create fine geometries and a tight, perfectly coupled fit.
The overall experience of gaming on a high-performance graphics card is very much influenced by its heat and noise output. The ideal card is fast, but stays cool and quiet.
The GeForce GTX 690 is cooled via a pair of custom vapor chamber heat sinks. Unlike a traditional heat sink that uses conduction to move heat away from the GPU, a vapor chamber exploits the superior heat conducting characteristics of evaporation. Inside each vapor chamber is a small amount of purified water. As the GPU heats up, the water evaporates, carrying away heat in the process. Once the vapor reaches the top of the fin stack, it cools, condenses, and the process repeats itself. It's similar to a miniature form of water cooling but, because the liquid is entirely self contained, there's no need for tubing and no chance of leaks.
Channeling air through the heat sinks is a center-mounted axial fan. The smoother the airflow, the lower the noise output. Here, our engineers spent considerable effort optimizing the fin pitch and angle at which the air hits the fin stack. The area directly underneath the fan is carved with low-profile channels to encourage smooth airflow and all components under the fan are low-profile so they won’t cause turbulence or obstruct airflow. Our acoustic engineers also fine-tuned the fan's control software so changes in fan speed occur gradually rather than in discrete steps.
The sum total of these efforts is not only in lower noise output, but also a less-perceptible noise. By eliminating board clutter, high-frequency sounds are removed. When you listen to the fan alone, it's clean and smooth.
A dual-GPU graphics card is similar to two-way SLI condensed into a single graphics card. Historically, though, the dual-GPU card has always lagged behind its SLI counterpart in terms of performance. When two GPUs are brought onto the same card, their combined heat output outstrips the capacity of even the most capable cooler. As a result, clock speeds must be lowered. For example, in the Fermi generation, the fastest single-GPU graphics card had a graphics clock speed of 722 MHz and a memory data rate of 4008MHz. On the dual-GPU card, the graphics clock was 607 MHz and the memory data rate was 3212 MHz.
This is where Kepler's fanatical focus on power efficiency pays off most handsomely. The GPUs on the GeForce GTX 690 have a boost clock of 1019 MHz, just a hair (2.8%) shy of the GeForce GTX 680 at 1058 MHz. What's more, all other specs are identical; the number of cores, memory speed, and memory bandwidth per GPU are the same on both cards.
What this means is that the GeForce GTX 690 performs more or less just like a pair of GeForce GTX 680s in SLI; almost nothing was compromised in bringing two Kepler GPUs to the same board.
In gaming performance, the GeForce GTX 690 is truly amazing, playing almost all of today's games at maximum settings with little effort. To really stretch its legs, you want to hook up three monitors and play your favorite games at 5760 x 1080, in NVIDIA Surround mode or, better still, in NVIDIA 3D Vision Surround.
Despite the stupendous performance of the GeForce GTX 690, some gamers are destined to clamor for more. That's where Quad SLI comes in. When two GeForce GTX 690s are connected via an SLI motherboard, four GPUs work in unison in Quad SLI mode. Each GPU works on a distinct frame for a total of four frames in flight at a given time. The resulting performance is simply otherworldly.
In Battlefield 3, at 2560 x 1600 with all settings maxed out, the framerate exceeds 120 FPS. Crysis 2 runs just shy of 100 FPS. And in the most demanding game, Metro 2033, the performance scales almost linearly to reach 56 FPS.
NVIDIA FXAA and Adaptive V-Sync, two technologies we introduced at the GeForce GTX 680 launch, become even more useful on the GeForce GTX 690.
Gaming at high resolutions, especially in Surround mode, consumes a large amount of memory. Traditional MSAA, which typically consumes 4x the memory, often becomes impractical to use. FXAA, on the other hand, consumes no additional memory and achieves comparable if not superior results, making it possible to game at oversized resolutions with antialiasing enabled.
Similarly, Adaptive V-Sync, which toggles V-Sync on and off depending on the frame rate, is a natural partner to the GeForce GTX 690. At very high frame rates, frames tear not just in two, but into multiple, discrete bands. With Adaptive V-Sync enabled, a solid 60 FPS can be maintained without tearing. And should the frame rate dip below 60, V-Sync is dynamically disabled to prevent stuttering.
Kepler introduces hardware based frame rate metering, a technology that helps to minimize stuttering. In SLI mode, two GPUs share the workload by operating on successive frames; one GPU works on the current frame while the other GPU works on the next frame. But because the workload of each frame is different, the two GPUs will complete their frames at different times. Sending the frames to the monitor at varying intervals can result in perceived stuttering.
The GeForce GTX 690 features a metering mechanism (similar to a traffic meter for a freeway entrance) to regulate the flow of frames. By monitoring and smoothing out any disparities in how frames are issued to the monitor, frame rates feel smoother and more consistent.
The work of integrating two full fledged-GPUs onto a single board is a tremendous engineering challenge. It is a perpetual tug of war between the constraints of performance, power, heat, and noise. The end product is almost always a compromise.
The GeForce GTX 690 may very well be the first dual-GPU graphics card that emerged in full form, free from compromise. It’s the world's fastest graphics card by a wide margin. It’s quieter and consumes less power than its predecessor. It’s crammed with features that eliminate jaggies and sustains smooth framerates. And to top it off, it’s made of the finest materials, expertly constructed, and with a look that speaks directly of the power that is housed within.
Features:-
- The worlds fastest graphics card!
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- PLX PCI-E 3.0 Bridge Chip (Gen3)
- Core Clock: 915MHz (GK104) x2
- Core Boost Clock: 1019MHz x2
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Memory: 4096MB GDDR5 (2x 2GB)
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 512-Bit (2x 256-Bit)
- Processing Cores: 3072 (2x 1536)
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 3x Dual-Link DVI-I, & 1x Mini-Displayport
- SLI Ready
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 300 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£829.99] Inc. VAT
Only £799.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 680 Phantom 4096MB GDDR5 PCI-Express Graphics Card @ £467.99 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Gainward GTX 680 Phantom, continue the elegant design of the first generation. The new Phantom II comes with brand new fins design (patent pending) that introduces 1) better thermal performance 2) lower acoustic level 3) more solid structure than previous generation. With this new outstanding innovated thermal design and optimized product design Gainward GTX 680 Phantom delivers an extreme gaming performance for enthusiast gamers.
Gainward Grand-Prix Heat-Pipes Hybrid Cooler, was designed in 6 mm copper-water heat-pipes on a copper base conducting heats away from GPU at highest efficiency, then dissipating onto aluminum heatsinks, which are forced ventilated with Great 8 cm silent PWM fans (GR8).
Great 8 cm silent PWM Fan (GR8) achieves highest cooling performance at much lower temperatures under power saving mode.
Gainward provides 4 ports in one, fulfills universal connectivity to diverse displays in extreme high-definition resolution. Dual View is supported with ease without bothering connector conversion.
Features:-
- The power of 3-way NVIDIA SLI® technology
Specification:-
- Core Clock: 1084MHz (GK104)
- Core Boost Clock: 1150MHz
- Gainward 6+2-Phase PWM for improved OC headroom and power stability
- Memory Clock: 6300MHz (Effective)
- Memory Interface: 256-Bit
- Memory Bandwidth: 201.6GB/s
- Processing Cores: 1536
- Shader Clock: 2168MHz
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 215 watts at stock speed)
- 1x 8-Pin PCI-E Connectors & 1x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 2 Years
Was [£499.99] Inc. VAT
Only £467.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 680 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £407.99 inc VAT
Features:-
Specification:-
- Memory: 2048MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£429.99] Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 680 "GOOD Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £389.99 inc VAT
This Gainward GOOD Edition is a Gainward Original Own Design product, making it ideal for overclockers with 1x 8-Pin and 1x 6-Pin power connectors for better overclocking ability.
Features:-
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1058MHz
- Shader Clock: 2012MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£399.95] Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 670 Phantom 2048MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
The GeForce GTX 670 graphics card taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It's more than state-of-the-art technology and features. It's truly game-changing performance.
Faster:
- Innovative new GeForce architecture-designed to deliver faster, more power-efficient performance
- The power to turn on lightning-fast antialiasing in a huge variety of games, automatically, with NVIDIA FXAA
- Support for new temporal antialiasing (TXAA) technique that delivers the ultimate combination of image quality and performance.
Smoother:
Richer:
- NVIDIA® Surround™ multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display)
Specification:-
- Phantom II Cooler for quieter and superior cooling
- Core Boost Clock: 1084MHz
- Memory Clock: 6108MHz (Effective)
- Processing Cores: 1344
- Shader Clock: 1930MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
- All order as of 09/11/2012 come with Borderlands 2 & Assassins Creed III PC Games FREE (Download Voucher codes)
Was [£329.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 660TI 2048MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
The Gainward GeForce GTX 660Ti graphics card adds a new dimension to the game-changing NVIDIA Kepler-powered family. Delivering the ideal combination of performance, power efficiency and affordability. It's a must-have upgrade for today's hottest and most demanding games.
Specification:
- Graphics Engine: NVIDIA GeForce GTX 660 Ti
- Bus Standard: PCI Express 3.0
- Video Memory: GDDR5 2GB
- Engine Clock: GPU Boost Clock : 980MHz
- GPU Base Clock : 915MHz
- CUDA Core: 1344
- Memory Clock: 6008MHz (3004MHz GDDR5 )
- Memory Interface: 192-bit
- Resolution: DVI Max Resolution : 2560x1600
- Interface: DVI Output : Yes x 1 (DVI-I), Yes x 1 (DVI-D)
- HDMI Output : Yes x 1
- Display Port : Yes x 1 (Regular DP)
- HDCP Support : Yes
- Accessories: 1 x DVI to D-Sub adaptor
1 x Power cable
- Software: ASUS GPU Tweak & Driver
- Dimensions: 10.7 " x 5.4 " x 1.7 " Inch
- 2yr Warranty
Was [£239.99] Inc. VAT
Only £227.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 650Ti Boost Golden Sample 2048MB GDDR5 PCI-Express Graphics Card @ £137.99 inc VAT
Introducing GeForce GTX 650 Ti BOOST, the latest addition to the award-winning NVIDIA® Kepler™-powered family of gaming GPUs.
GeForce GTX 650 Ti BOOST gives you 66% more memory bandwidth, NVIDIA SLI®, and NVIDIA GPU Boost technology that dynamically maximizes clock speeds, delivering class-leading performance to the GTX 650 family. Plus, this newly designed GPU offers an impressive 30% performance improvement*, so you can play all your favorite games at full-HD resolutions and high quality settings.
See how GeForce GTX 650 Ti BOOST can turbocharge your game in first-person shooters like Call of Duty, massively multiplayer online adventures like World of WarCraft, and real-time strategy titles like StarCraft II.
* Performance improvement measured versus GeForce GTX 650 Ti on 3DMark11
Specification:-
- Boost Clock: 1072MHz
- Memory Interface: 192-Bit
- Processing Cores: 768
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue VGA, 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 6-Pin PCI-E Connectors required
- Warranty: 2 Years
Was [£149.99] Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 650Ti Boost Golden Sample 1024MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
Specification:-
- Memory: 1024MB GDDR5
- Memory Clock: 5102MHz (Effective)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£129.95] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Gainward GeForce GTX 650Ti 1024MB GDDR5 PCI-Express Graphics Card @ £95.99 inc VAT
NVIDIA launched a new era in gaming with the NVIDIA® Kepler™-powered GeForce GTX family. Now, there are two new ways to experience the fastest, most efficient and powerful generation of graphics cards for yourself. Take your gaming experience to the next level with the GeForce® GTX 660-the weapon of choice for gamers-or the powerful yet remarkably priced GeForce GTX 650. Choose your weapon. Game on!
Specification:-
- Core Clock: 928MHz (GK104)
- Memory Clock: 5400MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 384
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI, 1x Mini-HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 100 watts at stock speed)
- Warranty: 2 Years
Was [£101.99] Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
Also Gainward 7xx series cards are looking very nice indeed. ;)
That's a good deal you struck up with the cooler removal clause well done prices are still a tad high but heading in the right direction :)
Been having problems with my PC , have a radeon HD5850 and would like to go back to nvidia and see if my problems go away .
With a max £150 to spend , would this be a good choice http://www.overclockers.co.uk/showproduct.php?prodid=GX-174-GW&groupid=701&catid=1914 , it comes under the red in the warranty section , but it's OC that sorts that out so that's okay isn't it ?
also what does it mean by "Golden Sample" ?
And when does the week end with these offers .
Thanks .
Thanks .
From a quick look, higher boost clock and wider memory bus.
That's the same with all the "boost" 650Tis though.
Edit: Wednesday.
I am not in the market for new cards yet but, big thanks to Gainward on the ability to remove the cooler without voiding warranty :)
