General Headphone Audio
Sennheiser HD555's and PC 363D. The HD 555's are used with an X-Fi Extreme Music sound card and of course the PC363D's use the USB 3D G4ME1 device. The HD 555's combined with the X-Fi produces a better listening experience in music and games and is more comfortable to wear than the PC 363D, I have had the HD 555's for quite a long time so maybe the PC 363D needs breaking in, the PC 363D is tight on the head and temples and the microphone sounds no different to the microphone on a 25 quid cheap pair of headsets with mic like the creative fatal1ty that I tried out. The PC363D G4ME1 usb device has dolby technology built in but in game and music is just fake surround, sometimes difficult to tell but I suppose this would depend on the games audio development?.
I use a pair of Sennheiser HD800s for anything music related, but I need to get myself some cheaper general purpose headphones. I certainly don't fancy cable tie'ing a Track IR clip to those beauties.
This is what I have:
1. Grado GS1000i: For my main audio setup, connected to a NJC Monitor II & DAC.
2. Audio Technica ATH-M50: Mostly for music while I travel where portability is not much of a concern or to use at work.
2. Sennheiser IE8i: Mostly used now for when I feel I may need the microphone or when it's inconvenient to be carrying the M50s. These used to be my main travel headphones but they had a tendency to keep slipping out of my ears.
Good lord!! Impressive! :eek:
Hd 25 ii.
Good bass, treble and easy to drive, isolation and probability use, clean sounding and crisp.
A popular pick for djs i think and what i have read.
They sound good.
Hd 25 ii.
They sound good.
Not just DJs but for TV as well, BBC tend to use them a lot and the versions with the mics.
AKG Q701 with Fiio E6. They're fantastic, if they ever break then I'll probably buy another pair. Not great if you're really into bass though.
Asus Xonar DG 5.1 with Sennheiser 515's. Prior to the 515's I owned set of Razer 5.1 'gaming' headphones, the sound quality was very good but I found the surround sound feature of them to be gimmicky and they got hot after about an hour of use. Also the extra speakers made them heavy so after a prolonged period of use the weight of heat of them made them uncomfortable to wear, the best thing I every done was getting those returned and buying a the Sennheisers instead.
My next move will be upgrade the sound card, it's a bit better then onboard audio as you don't get the interference noise but the headphone amp is a bit of a feather weight. Anyone got any suggestions?
well the list needs updated as ive not added the things from the last couple months but here the copy paste from my headfi profile
Sennheiser CX 300
Creative EP-630
Shure SE210
Shure SE530
Shure E3
Shure SE110
Denon C751
Klipsch Custom 1
Klipsch Custom 2
Sony MDR-EX500LP
Ultimate Ears Triple.Fi 10 Pro
Sennheiser IE7
Klipsch Custom 3
Etymotic ER-4P
C-Jays
Sennheiser IE8
Radiopaq Pop
Philips SHE9850
Westone UM3X
Soundmagic PL-50
Radiopaq Jazz
Head Direct RE-0
V-Jays
iMetal iM-590
Denon C710
Head Direct RE-252
Sennheiser MX760 - Given away
MEElectronics M2
MEElectronics M6
MEElectronics M9 - Gone to a friend in need who keeps breaking things
MEElectronics M11
MEElectronics R1
Westone UM2
Grado 325is - Swaped for W4's
Radiopaq Classical
Ultimate Ears Super.Fi 3
JVC FX500
JVC FX300
Panasonic HJE900 - Got Swapped
Audio Technica CK10
Vsang R03
Sennheiser HD600
Ultimate Ears Super.Fi 4
Phiaton PS320
Brainwavz M1
HiFiMAN RE-ZERO
MeElectronics M11P+ - Have gone to a friend in dire need
Ultimate Ears Super.Fi 5vi
Ultimate Ears Loud Enough
Ultimate Ears UE700
Jays Q-Jays
Sennheiser CX380
Shure SRH840
Sennheiser RS110 - Given Away
Sennheiser HD515
Sennheiser RS180
Thinksound Rain
Etymotic MC3
Etymotic HF3
HiFiMAN RE-262
Braimwavz M3
Fischer Audio Enigma Revision 2
Fischer Audio DBA-02
Sennheiser HD218
Jays a-JAYS two
ECCI PR401
Sunrise i100
Sunrise Xcape v2
Vsonic GR07
MEElectronics SP-51P
MEElectronics CC-51P
Sunrise Xcape Impressive Edition
Sunrise Audio Xcited
HiFiMAN RE-272
Vsonic GR04 Pro
DUNU Trident (DN-12)
DUNU Ares (DN-11)
DUNU Hephaes (DN-16)
Spider Realvoice - Given to a friend
Hisoundaudio Crystal
Brainwavz B2
Brainwavz Beta v2
Hisoundaudio Popo
Fischer Audio Tandem
Fischer Audio Falcon
Hisoundaudio Golden Crystals
MEElectronics A151
TFTA-2100-2V1S
Fischer Audio Golden Wasp
Blox M2C
Vsonic GR06
EXS X10
Dunu I3C-S
Dunu Crater (DN-17)
Dunu Hawkey (DN-18)
Vsonic GR99
Vsonic GR01
Brainwavz M4
NuForce NE-770X
NuForce NE-600X
Hisoundaudio Wooduo 2
RHA MA-350
Dunu Tai Chi (DN-19)
Sennheiser CX985
Yamaha EPH-20
Denon AH-D1100
Frogbeats C3
HiFiMAN RE-400
Telefunken TH-140
Musical Fidelity EB-50
Rock It Sounds R-50
Telefunken TH-120
t-JAYS Four
Nuforce NE-700m
DUNU Detonator DN-22m
Cowon EH2
Vsonic VC02
BLOX BI3
DUNU DN-23
