my i7 3770k overclocking results
9 Dec 2006
@ManCave
before you go on at me your doing terrible etc
i've only been overclocking a weekish
trying to play slow & safe :)
quick testing [just to see what it would tolerate to boot]
4.2ghz @ 1.125 (stock) my board
4.4ghz @ 1.150
4.5ghz @ 1.185
proper testing [finding the lowest voltage on each OC + 24 hours prime
3.5ghz @ 0.800
4.0ghz @ 0.950
4.3ghz @ 1.096 < might even stay here:D << top temp on prime 48c
validation in case of none believe
http://valid.canardpc.com/2800107
Under 1.1V at 4.3 is very good.. Would be good to see lowest voltage on 4.5.
What motherboard/cooler are you using?
EDIT: you sig is telling lies, you voltage is 1.184 not 1.84, i bleeding hope so anyway. :)
yeh it is :)
msi mpower z77 phantek cpu cooler (double heatsink one)
not retried 4.5 yet
i dont no a safe voltage for 24/7 so dont want to push to much
remember to test in games after ibt/prime95 stable
it will tend to crash to desktop if your cpu voltage is too low even after passing stress tests
tbh your looking at 1.2-1.212v for 4.5ghz unless you have a super duper golden chip:D
look in event viewer for whea parity 19 processor warnings/errors
It is really hard to find a definitive safe voltage. I have read that 1.2 is recommended but not too sure. If 4.5 stays stable id say that its a great 24/7 OC.. Then push, see what you can hit. :)
been playing games since my last post all running fine. so far & event viewer is free of errors
max temp so far is 44c in games:D prime hit 52c
http://valid.canardpc.com/2800432
(sorry it was 4.4 not 4.5
overclocking is fun and bit addictive :D :(
temps whilst gaming
going to keep this till tomorrow
to make 100% sure its solid then make try 1.135 voltages to see if thats stable (i jumped from 1.125 to 1.144 right away.
from there i might go up:D
im guessing 1.144 is good for the speed??
not got the any fans installed on the case anymore just 2 intakes
cpu pushes out of the top fine :)
https://www.dropbox.com/s/h4s4hfb2cm4foxs/IMG_2800.JPG
Ive seen where the voltage varys quite a bit oc theses chips and yours seems to fall into the lower ones, proberly quite a bit of overclocking headroom left
