Which upgrade to my computer?
14 Oct 2011
Kent
Option 1:
6950
Option 2:
2500k
Right now my specifications are:
Intel Celeron G530 (1155)
MSI Z68A-GD65
2x4gb RAM
5770gpu
OCZ CoreXstream 500w PSU
So, I would go with the 6950, but I am not sure if my PSU will be able to cope with it. I used a PSU calculator :)rolleyes:) and with 10% Capacitor aging, 100% cpu load and 100% system load. With all of my fans etc...
Which will give me a good upgrade, I game mostly and render long 720p videos. They take a bit long to render, but I am not sure whether CPU rendering would be better than GPU rendering.
Thanks
T345
13 Oct 2011
Melbourne, Australia
Are you only able to do one of the upgrades?
The 2500k will improve your rendering no end, over clock it and it'll be better.
The 6950 will make your gaming better, a lot better. Though you will need a new PSU...
Could you.afford the 6950 in a few months time..
OP
14 Oct 2011
Kent
Well, I am selling some things, so I will have enough for one in a few weeks, and the other maybe in a few months.
12 Feb 2009
Go with the HD6950 to start with.
Check sticker on side of the PSU if the Combined +12V is 350 W or more you should be fine.
The only reference I can find is it has 25 A / 20 A on the two 12V rails; combined 12V power max. 444W.
If that is the case then the PSU is fine.
25 Jun 2007
Buckinghamshire
That's correct 45 Amps across two rails. I have the PSU it's been happily running my PII X4 and 6850 for a year now.
You should get away with a 6950 but you would be pushing the PSU to its limit.
