- 1 Jun 2010
- Bedford
I wonder if there will be a 9990: x2 4096 SP (8192 SP)![]()
Or better Quadfire 9990!!
No idea how relevant this is, but i'm looking at my Heaven Vally thread.
2x 7970 @ 1250 / 1700 / (2x 2048 SP's) = 4117
1x 7970 @ 1230 / 1794 / (1x 2048 SP's) = 2197
That's 95%+ GPU scalling
This spec also has +100% ROP's (64) / +34% Memory bandwidth (512Bit)
Added on are 16 Parallel Processing Units (no idea what that will do to performance)
And (add Shader Core optimisation?)
Its hard to say, but I am really looking forward to the end of this year....
Where is that AMD driver which is meant to give great Crossfire performance, reduced frame latency and stuttering? I read about it maybe a month ago being released at the same time as the 7990 but has it been released?
They are testing it (prototype driver) and it gives good results but not due for public release till June/July.
2 x 7970's have a total memory bandwidth of 384-bit x 2 = 768
so it is actually a 33% reduction in memory bus
bandwidth lost could be made up for with faster memory though - not sure what is in the pipeline between now and end of the year
yes... right now, you have 1 GPU working on frame 1 and GPU 2 working on frame 2
they both get the full 384bit bus to play with while they work (VRAM amount is mirrored so you only get that once, but the bandwidth is dedicated to each chip so it counts twice)
when you move to 1 single GPU, if it were to try and work the same way (e.g. half the chip working on a single frame and the 2nd frame being worked on by the other half) then the whole GPU only gets the bandwidth once, so in this example, each frame only gets half the bandwidth
if that makes sense?
Here they are saying that AMD's next will still be based on 28nm - http://translate.google.com/transla...-and-hello-volcanic-islands-05122013/&act=url.
Taking all of these leaks with pinch of salt..
Hawaii also will not use the 20nm process, will continue the existing 28 nm process, the limitations of the process specification seems unlikely to do so violent, so what 4096SP what 512bit bus, we can only dream to meet the ... XD. Into the HSA heterogeneous architecture era seems to have been determined, the next step is to wait for AMD will bring out what kind of products to consumers.
Further information or detailed specifications, technical illustrations and data, we will continue to follow-up reports.
But there was a new about TSMC being ahead of their own roadmap:I reckon if they stay on 28nm then it will be a huge core, if they do go for 20nm then it will be about the same size as the currant chip, but I doubt that it will be available by the end of the year, knowing the usual delays at TSMC.
Yeah, your probably looking at £500+ But hell if its twice the 7970 on one chip its worth it.
This is the bit that stops me from taking any of these rumours seriously. Even if the GPU is twice as powerful as a HD 7970 it would be unlikely that AMD would simply double up on the HD 7970s specs add a 512bit bus and leave it at that. The only people who are likely to do this are the people who spread rumours.
When this GPU does appear I would expect it to have an entirely new layout compared to a HD 7970.
Like adding 16 Parallel Processing Units?
@ 20nm the DIE would be roughly the same size as the 7970.
Its unbelievable in the performance gain it would achieve, but in terms of technicality its completely believable.
AMD may mess about and make the 20nm with less than 4096 SP's (3000 perhaps?) a smaller DIE size than the 7970.
Or they may just be thinking, "we will not get caught out by Nvidia again, just go all in for it"
The thing is Nvidia have such a huge and dogged fan following, the only way they can gain back much needed market share is just to throw everything in, go maximum and hope its enough to muller whatever Nvidia do and make a clear undeniable difference between them.
Its what I would look to do.
If AMD haven't learnt anything from messing about by now they are idiots.
Time will tell![]()
