## VidCoder 1.4.19.0 (x64)
# Starting scan: F:\Various Downloaded bits\Tron_Trailer_HD.mov
[21:30:04] hb_init: starting libhb thread
[21:30:04] hb_scan: path=F:\Various Downloaded bits\Tron_Trailer_HD.mov, title_index=0
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening F:\Various Downloaded bits\Tron_Trailer_HD.mov/BDMV/index.bdmv
libbluray/bdnav/index_parse.c:162: indx_parse(): error opening F:\Various Downloaded bits\Tron_Trailer_HD.mov/BDMV/BACKUP/index.bdmv
libbluray/bluray.c:1725: nav_get_title_list(F:\Various Downloaded bits\Tron_Trailer_HD.mov) failed (0000000029BC8910)
[21:30:04] bd: not a bd - trying as a stream/file instead
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav
VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav
VDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[21:30:04] dvd: not a dvd - trying as a stream/file instead
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'F:\Various Downloaded bits\Tron_Trailer_HD.mov':
Metadata:
creation_time : 2010-11-30 18:11:55
copyright : © Disney
copyright-eng : © Disney
comment : Im Verleih der Walt Disney Studios Motion Pictures
comment-eng : Im Verleih der Walt Disney Studios Motion Pictures
title : TRON - LEGACY
title-eng : TRON - LEGACY
Duration: 00:02:28.84, start: 0.000000, bitrate: 15237 kb/s
Stream #0.0(eng): Video: h264 (Main), yuv420p, 1920x816 [PAR 1:1 DAR 40:17], 14914 kb/s, 24 fps, 24 tbr, 600 tbn, 48 tbc
Metadata:
Stream #0.1(eng): Audio: aac, 44100 Hz, stereo, fltp, 320 kb/s
Metadata:
[21:30:04] scan: decoding previews for title 1
[21:30:04] scan: 10 previews, 1920x816, 24.000 fps, autocrop = 0/0/0/0, aspect 2.35:1, PAR 1:1
[21:30:04] libhb: scan thread found 1 valid title(s)
# Scan completed
# Starting queue
# Starting job 1/1
# Path: F:\Various Downloaded bits\Tron_Trailer_HD.mov
# Title: 1
# Range: All
# Worker ready: Service state is Opened on pipe VidCoderWorker.e9e29a17-3812-414d-a13a-c793f6e29b6b
# Connecting to process 2600 on pipe VidCoderWorker.e9e29a17-3812-414d-a13a-c793f6e29b6b
[21:30:47] hb_init: starting libhb thread
dvd: ifoOpen failed
[21:30:47] hb_scan: path=F:\Various Downloaded bits\Tron_Trailer_HD.mov, title_index=1
libbluray/bluray.c:1725: nav_get_title_list(F:\Various Downloaded bits\Tron_Trailer_HD.mov) failed (0000000000811180)
[21:30:47] bd: not a bd - trying as a stream/file instead
libdvdnav
libdvdnav
Metadata:
Metadata:
Metadata:
[21:30:47] scan: decoding previews for title 1
[21:30:47] scan: 10 previews, 1920x816, 24.000 fps, autocrop = 0/0/0/0, aspect 2.35:1, PAR 1:1
[21:30:47] libhb: scan thread found 1 valid title(s)
[21:30:48] 1 job(s) to process
[21:30:48] starting job
[21:30:48] yadif thread started for segment 0
[21:30:48] yadif thread started for segment 1
[21:30:48] yadif thread started for segment 2
[21:30:48] yadif thread started for segment 3
[21:30:48] decomb filter thread started for segment 0
[21:30:48] decomb filter thread started for segment 2
[21:30:48] decomb filter thread started for segment 3
[21:30:48] decomb check thread started for segment 0
[21:30:48] decomb filter thread started for segment 1
[21:30:48] decomb check thread started for segment 1
[21:30:48] mask filter thread started for segment 1
[21:30:48] mask erode thread started for segment 0
[21:30:48] mask filter thread started for segment 0
[21:30:48] mask dilate thread started for segment 0
[21:30:48] decomb check thread started for segment 3
[21:30:48] mask filter thread started for segment 2
[21:30:48] mask filter thread started for segment 3
[21:30:48] mask dilate thread started for segment 3
[21:30:48] Passthru requested and input codec is not the same as output codec for track 2, dropping track
[21:30:48] work: sanitizing track 1 mixdown Dolby Pro Logic II to Stereo
[21:30:48] work: track 1, compression level not supported by codec
[21:30:48] work: track 1, quality mode not supported by codec
[21:30:48] work: track 1, dithering not supported by codec
[21:30:48] sync: expecting 3572 video frames
[21:30:48] mask erode thread started for segment 1
[21:30:48] job configuration:
[21:30:48] * source
[21:30:48] + F:\Various Downloaded bits\Tron_Trailer_HD.mov
[21:30:48] + title 1, chapter(s) 1 to 1
[21:30:48] + container: mov,mp4,m4a,3gp,3g2,mj2
[21:30:48] + data rate: 15237 kbps
[21:30:48] * destination
[21:30:48] + F:\Various Downloaded bits\Tron_Trailer_HD.mp4
[21:30:48] + container: MPEG-4 (.mp4 and .m4v)
[21:30:48] + 64-bit formatting
[21:30:48] * video track
[21:30:48] + decoder: h264
[21:30:48] + bitrate 14914 kbps
[21:30:48] + frame rate: same as source (around 24.000 fps)
[21:30:48] + filters
[21:30:48] + Decomb (default settings)
[21:30:48] + Framerate Shaper (0:27000000:1125000)
[21:30:48] + Crop and Scale (1920:816:0:0:0:0)
[21:30:48] + source: 1920 * 816, crop (0/0/0/0): 1920 * 816, scale: 1920 * 816
[21:30:48] + loose anamorphic
[21:30:48] + storage dimensions: 1920 * 816, mod 2
[21:30:48] + pixel aspect ratio: 1 / 1
[21:30:48] + display dimensions: 1920 * 816
[21:30:48] + encoder: H.264 (x264)
[21:30:48] + x264 preset: medium
[21:30:48] + h264 profile: high
[21:30:48] + h264 level: 4.1
[21:30:48] + quality: 20.00 (RF)
[21:30:48] * audio track 1
[21:30:48] + decoder: English (aac) (2.0 ch) (track 2, id 0x1)
[21:30:48] + bitrate: 320 kbps, samplerate: 44100 Hz
[21:30:48] + mixdown: Stereo
[21:30:48] + encoder: AAC (faac)
[21:30:48] + bitrate: 160 kbps, samplerate: 44100 Hz
[21:30:48] decomb check thread started for segment 2
[21:30:48] mask erode thread started for segment 2
[21:30:48] mask erode thread started for segment 3
[21:30:48] mask dilate thread started for segment 2
[21:30:48] mask dilate thread started for segment 1
[21:30:48] reader: first SCR 0 id 0x0 DTS 0
[21:30:48] encx264: min-keyint: 24, keyint: 240
[21:30:48] encx264: encoding with stored aspect 1/1
[21:30:48] encx264: Encoding at constant RF 20.000000
x264 [warning]: --psnr used with psy on: results will be invalid!
x264 [warning]: --tune psnr should be used if attempting to benchmark psnr!
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSEMisalign LZCNT
x264 [info]: profile High, level 4.1
[21:34:17] reader: done. 1 scr changes
[21:34:21] work: average encoding speed for job is 16.904037 fps
[21:34:22] sync: got 3572 frames, 3572 expected
[21:34:22] decomb: deinterlaced 0 | blended 61 | unfiltered 3510 | total 3571
[21:34:22] render: lost time: 0 (0 frames)
[21:34:22] render: gained time: 0 (0 frames) (0 not accounted for)
[21:34:22] h264-decoder done: 3572 frames, 0 decoder errors, 0 drops
x264 [info]: frame I:107 Avg QP:16.59 size: 89252 PSNR Mean Y:50.93 U:55.69 V:56.73 Avg:51.96 Global:50.47
x264 [info]: frame P:2527 Avg QP:19.39 size: 26548 PSNR Mean Y:48.06 U:52.31 V:53.06 Avg:48.99 Global:47.53
x264 [info]: frame B:937 Avg QP:19.58 size: 9388 PSNR Mean Y:51.97 U:55.94 V:56.87 Avg:52.72 Global:46.70
x264 [info]: consecutive B-frames: 56.3% 24.9% 3.5% 15.2%
x264 [info]: mb I I16..4: 51.9% 25.8% 22.3%
x264 [info]: mb P I16..4: 20.1% 9.8% 1.2% P16..4: 35.5% 8.4% 4.6% 0.0% 0.0% skip:20.5%
x264 [info]: mb B I16..4: 2.5% 0.8% 0.1% B16..8: 31.2% 2.4% 0.6% direct: 4.4% skip:58.0% L0:41.7% L1:52.1% BI: 6.2%
x264 [info]: 8x8 transform intra:30.5% inter:74.4%
x264 [info]: coded y,uvDC,uvAC intra: 44.8% 50.6% 21.7% inter: 19.5% 26.9% 1.5%
x264 [info]: i16 v,h,dc,p: 35% 22% 25% 17%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 21% 39% 4% 4% 4% 5% 4% 4%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 25% 26% 5% 7% 5% 6% 4% 4%
x264 [info]: i8c dc,h,v,p: 58% 21% 16% 6%
x264 [info]: Weighted P-Frames: Y:17.0% UV:14.5%
x264 [info]: ref P L0: 59.4% 9.0% 21.7% 9.4% 0.5%
x264 [info]: ref B L0: 77.4% 21.4% 1.1%
x264 [info]: ref B L1: 97.3% 2.7%
x264 [info]: SSIM Mean Y:0.9865977 (18.728db)
x264 [info]: PSNR Mean Y:49.174 U:53.362 V:54.171 Avg:50.056 Global:47.357 kb/s:4592.15
[21:34:23] aac-decoder done: 0 frames, 0 decoder errors, 0 drops
[21:34:23] mux: track 0, 3571 frames, 85429907 bytes, 4590.69 kbps, fifo 1024
[21:34:23] mux: track 1, 6412 frames, 2888922 bytes, 155.24 kbps, fifo 2048
[21:34:23] libhb: work result = 0
# Job completed
# Queue completed
