- 31 Dec 2008
Is it really
The PSU isn't great to be honest, isn't even bronze rated. The H61 mobo most likely doesn't have sataIII (there are only a few exceptions that do) to make the most of SSDs. Infact some H61s don't support Ivybridge CPUs without a BIOS update either.
The 7750/7770 isn't great value. I used the 650Ti boost for a reason. If he is on a tight budget he should try and hunt down a 1GB 460 on the MM (should be around £50ish) which overclocks well and will soundly spank the 7750/7770
bah didnt see your spec, (the 1 with the pentium and the 650) that is better!
