I wanna replace the stock fans on my H100i but have a few questions I hope you can help with.
Looking at these fans. Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin AP-15's. I hear they are very good with good pressure and low noise.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-030-SY&groupid=701&catid=2331&subcat=4
Will they fit under the top grill on the 600T? The stock H100i fans are already a tight fit under there.
Can I connect them directly to the H100i just like the stock fans and control them through the LINK program?
Thanks
Thanks
