Oven Imploded: Just the right moment.
Same thing happened to my sister in law when she stayed in one of those static caravans earlier this year. Even though glass flew everywhere and they were in the caravan at the time thankfully no one got hurt.
They received £20 in food vouchers from the park
So is this a dead cert on cheap ovens? Or is it to do with it heating up too quickly?
Most of the breakages happened while building them so had never been turned on.
In the test lab there was no specific reason why door glass broke so we put it down to cheap glass.
When the glass was made in Wales we never had problems and then I think it started coming from Czechoslovakia.
That's really concerning as it could take your eye out!
I was lucky that I was at the dining table with the case to the right of the pick, otherwise im sure I would have some shards in me.
To be honest I've never seen one break and it shoot out where it could take your eye out or else we would have had a lot of one eyed workers.
The glass just broke and fell to the floor and workers would have to put a new door on and usually work on top of the glass until gap time came.
If this has shot across the room then some other factor has taken place.
I was in the middle of it when the oven went kablam. and yes the crysis benchmark was a bit too much for the poor oven.
Seriously, tile all the way back if you can. The amount of appliances we go to that can't be removed because they have been tiled in is frightening.
I can well believe it. I also wonder why really important stuff like main stopcocks are inevitably located in inaccessible locations :(
Recently I had to help to remove an old washing machine from a friends house. The washing machine taps had seized solid and when I tried to turn off the main stopcock so I could replace them, that was seized too. I managed to turn it off eventually but it was a bit like James Herriot sticking his arm up a Cow! the stopcock was actually in a corner, in a bathroom unit behind the toilet and behind the soil pipe!
WTF are the builders thinking! :mad:
implosion due to a vaccum, the glass is then thrown outwards
What? Ovens don't run under reduced pressure or vacuum so I don't understand... There will be slightly increased pressure on the inside the oven due to the heated air so if anything that would create an explosion but the pressure difference would be neither here nor there so it isn't really either an explosion or an implosion... Just the glass making a loud noise as it failed.
