Sublime.Matt how's the M3 now?
90% of the mechanical bits are done and it is an absolute hoot to drive. Ive taken it to work everyday for the last two weeks (and this will sound sad) but il cannot wait to get out the door in the morning and i arrive at work beaming.
Recently changed the brake/clutch fluid, which resulted in two new front brake calipers. The brakes dont deteriorate when used hard now and the clutch feels much better. Now that it is on Koni dampers and not dead oe stuff, you can take massive liberties with the car (and hence brakes needing sorting and also mpg is tumbling again)
Another little fix has been the seal on a thing called the "constant pressure valve" which has fixed an oil leak.
Still lots to do, what do you expect from a car that has been utterly ruined.
The car turns heads wherever it goes, you get knowing looks/nods. I turned up at a bar the other week and a guy who was stepping outside for a cig walked up to the car to say how he hadnt seen one in ages. Turns out he was the bodyshop manager at my local BMW dealer, we ended up chatting till it closed... respray could be taking place at BMW now.
There is something that is more satisfying about a car that youve done so much work on, not in a "built not bought" way, but in a rescue and personalisation way, so yuoll love yours when youre done.
Next steps for me are the cosmetics. trims, lights, grills and rip out and sound deaden the whole interior
