GTX 680 or Radeon 7970
22 Apr 2009
Birmingham
Can can a leadtek GTX680 2gb or Gigabyte WF 7970 3GB.
Both the same price (£300), which one is the "better" card.
Are they the same price? What are you asking because your post doesn't match the title (7950 or 7970? Since when is a 680 £300?)
On balance it goes down to personal preference then. Does the 680 come with warranty and does they 7970 come with games? Which has the better acoustics? They much of a muchness, fanboyism aside.
7970, 1Gb extra vram, larger memory bus, better at higher res, AMD 3D(Tridef), free games slightly faster oc'ed than a 680 oc'ed in general.
680, 1Gb less vram, smaller memory bus, PhysX, Nvidia 3D.
If you are happy with Nvidia, stick with the devil you know, if you are at ease with both vendors, then take your pick. :)
Both are good, both will serve you well.
Being bit of an nvidia fanboy I can't stress how good the 7970 is more so in the later stages of it's life.
play at 1080p, currently plan to use a single card though not adverse to going SLI/xfrire in the future.
Looks like the 7970 is the one to go for.
Cheers
