Thunderbolt To Gigabit Ethernet Adapter - Worth It?
19 Dec 2003
UK
Hey guys,
For the new Retina MBP they do not have an Ethernet port so I just wondered, is there actually a noticeable difference using one of the Apple Thunderbolt to Gigabit Ethernet adapter over the built in Wireless option?
I would imagine for transferring large files via a LAN the wired version would be far superior, but what about day-to-day file downloading/browsing/uploading files?
Thanks
I get pretty much identical performance using airport as using the built in ethernet on my MBP. I've also found the wireless much easier to setup/use than on windows.
Never noticed any signification performance drop for internet on my macbook pro, always within 1-3Mbs of max net in speedtests.
I very much doubt your wireless connection will be your bottleneck for internet related tasks.
Mine does if I'm upstairs in the office. For this reason I've run a cable up form the router and use a Gigabit ethernet adapter.
Which USB3 adapters are people using? I'd actually quite like to replace my Thunderbolt one with a USB3 one so that I can use the second DisplayPort connection instead of the HDMI.
I got a cheap startech one of amazon for £9.99 a while back, after you install the drivers works flawlessly through a USB3 hub.
Does it work when the machine is in 'Power Nap' mode? Mine backups up normally when napping and it needs to be done over the cable.
The startech ones seem to be like £20-30 I wonder if the cheap omes woek 100% of the time.
Interested in this as I will need an rj45 Ethernet port when I get my rMBP in a few weeks, work in networking so it's a needed port.
Will be using 1/2 of the thunderbolt ports for monitors.
