- 19 Jan 2006
- Guernsey
http://www.ebay.co.uk/itm/50mm-Tubu...sure_cycling_bikeparts_SR&hash=item3f24ecd2d4 - The ones I bought.
(that being said I need to get a better picture of them in daylight!)you're into SS bikes, what would you recommend as a nice tough wheel set for a SS? budget up to 150 really.
34-28 is going to be easier than 38-26....go with the 11-25 cassette and compact (50-34) cranks if you feel happy with what you have at the moment.
If you are a beginner then consider the 12-28 though, at least it will give you some bail out on steeper and/or longer climbs.
EDIT
Try this to compare gear ratios:- http://www.bikecalc.com/gear_ratios
I would take a set of pedals with it and not bother about upgrading the wheels. You dont really need to upgrade the wheels (and you probably wouldnt even notice the difference anyway) but you will need pedals for it.
You're right, lighter wheels do make a huge difference. But is ~100g difference on a 2kg wheelset even going to be noticeable?That's suprised me everybody seems to go on about weight of wheels being a huge factor, is that just once you are at the top of your game?
[Damien];24284621 said:Don't forget to take the dustcaps off your innertube valves though. The reduction in rotational inertia will give you at least an extra 30w. If you wear any Rapha/Assos gear too you can multiply any perfomance increases by 3. Stick a pair of Oakleys on top and you'll be winning the TdF in no time!
Stock up on laxatives the day before a race as well.
I've heard baked beans are meant to be a great way to get a squirt of extra acceleration, just release the gas at the right time and it gives you an extra 5 watts. Make sure it's just a squirt of gas otherwise it could be rather embarrassing!
Ok thanks, that all makes sense. I've just been looking at more expensive, lighter wheels and realised its a total waste like you say.
Pedals and shoes were on my list anyway just not through the cycle scheme but I may aswell pay for the pedals over the next 18 months instead. Will keep the mrs happy!!
