surely that's not safer because of key loggers malware etc. out there?I have to manually insert my password every login. Same with personal details as well.
Sounds like the googlemail 2 step verification
Does seem a better system![]()
As for Key logger, i dont think there much defense once the logger is active on a client. However if you know what your doing,, it quite easy to check if there is anything harmful/malicious to your system. ie hijackthis, firewall activity, malware scanner etc comes to mind as well as other useful tools.
i thought using a on screen keyboard to enter passwords is safer?Aside from using the inbuilt keyboard to enter your password?
Can that be detected?
i mean a virtual keyboard like MS one, click-n-type (which i use), KIS virtual keyboardI didnt know there was a virtual keypad to login into steam so not entirely sure?, at first glance there should be no difference if there is a legitimate way in steam as both physical and virtual are just an input interface?
BOOM!
Sorted, Steam confirmed that my account was indeed hijacked......
Congrazt, nice to see you were sorted. It most likely nothing u could have done about it.
so from now on, after i redeem a code, i simply burn them. valve are idiots tbh.
