New rig problems? maybe. Need help.
29 Jun 2012
Hi all,
I recently, this morning in fact, received my new rig from overclockers. The ultimate 9300i with parts of my choice. I went with a msi geforce gtx680 and I was hoping to get some advise here...
I currently have the pc setup with good space all around it for ventilation. It's a cool master haf x case running front, side, rear and single top fan. the front and side pulling air in, the back and top pushing air out.
My room is currently 16 degrees C and because i've been paranoid all my life about temperatures I downloaded the msi afterburner tool. What its telling me has me worried (maybe)
It's been a long time since I had a nvidia card and even longer still since I had anything better than a ati hd 4880 (which used to idle at around 32c) The issue I'm having is that this 680's idle temps seem a little high to me.
With my room currently at around 16 degrees, no obstructions near the pc, im getting an idle temp of 50-51c. I know these new cards are designed to handle hotter temps but could someone shed some light on this?
My case fans are running about 800rpm (though i dont know how to speed them up if they needed it)
so yup, to cut it short - Room's at 16ish C, idle is 51c at 33% auto fan speed.
if anyone can ease my worry / tell me how to maybe cool it better, i'd appriciate it.
thanks
peace.
Seems a lot higher than ambient for idle. But since your load isn't much higher I wouldn't worry about it. GPU's can operate at around 100C with throttle points on the GTX600 series starting at 70C (if I remember right) I'd just be trying to figure out why your idle temps are what they are. Whats the CPU idle at?
I setup a simple afterburner profile and the gcard is now idle'ing at an acceptable 40ish, load is only just going over 50. when i compare it to the idle to load of my old pc that feels about right. in changing the fan profile on the gcard i've also noticed my cpu temps have dropped a little too. so i guess that was the problem.
thanks for the advice, helped a lot ^^
40° is perfectly fine, my 7870Xt idles at 34, not much lower than yours.
As long as your load temps are not ridiculous it will be ok, I like to keep my load temps around 60-70, 80 if for whatever reason it needs to.
I remember back in the days, had this 7800GTX, bought it second hand off the bay, guy never cleaned it before selling it and I never before fitting it...
...load temps hit about 105°, took me days to realise why in the hell my room was so bloody hot! lol
It's probably just slightly iffy temp sensors (not calibrated properly?)... My i5 3570K has uneven idle temps with as much as 10C+ difference between cores (when idling), but the temps even out under load with only a 1 or 2C difference between cores.
I have a HIS Radeon 7950 (boost version) in my main gaming rig that idles around 28-30C and maxes out at 61C (room temp is usually around 20-22c)... The giant blower type cooler on that thing is brilliant! My KFA2 GTX 660 Ti is currently idling at 29C while I type this, but it maxes out at a toasty 72C (despite having a large dual fan cooler!).
Your CPU Temps have dropped as your GPU is not pumping out a slow stream of really hot air. Because of the fans now running higher, its is pumping out more air, but its cooler. I suspect the concentrated hot air was getting sucked into your CPU Heatsink.
40 idle is good. How many screens are you running? More than one increases idle considerably as the card can no longer actually idle, instead it will sit on its 2D clock (50%)
When measuring load temps, what application were you running to get load?
Gaming will not give a true load. Try Furmark :)
