Road Cycling Essentials
Status
Not open for further replies.
:cool: Hopefully it will arrive some time next week rather than the week after!
That remains to be seen. I spoke to them and asked them to redo the transaction and the guy said they'd send me email confirmation. I haven't had it yet and their service center is shut so perhaps they'll redo it on Mon if it's not shipped today.
First time going out riding a set loop - http://app.strava.com/activities/54681164
Still very green so only did 5.5miles @ a very modest speed.
There's a good bit of climb, BIG drop and climb again. Think this will be my local training loop. Hopefully by end of summer I can easily do 8 laps.
What do you think? +1 lap, increase every week or fortnight to push?
Reverse your loop and do that big descent as a climb ;)
max 190 ?
not of your going pretty much max out or climb a hill that wasn't that easy?
I meant the average, i was pushing quite hard and had a slight head wind. And i'm more sprinter build being like 5"7' and 12 stone not like some of the whippets on here. :D As long as i know my new Garmin is working correctly then it's fine.
I guess I am a lazy cyclist, because your average heart rate is higher than my max heart rate on my last ride;
http://connect.garmin.com/activity/307304881
I guess I'll have to throw myself up some big hills tomorrow morning, just to see if it'll go any higher.
Your ride is private Saundie. Your max heart rate is dependant on age 190bpm is about the max for my age at 32.
Strange, I could have sworn I set it to public, but you are correct. It's no longer private.
I'm 28, so our theoretical max heart rates are not all that different. I never really push myself on the bike. I've seen it as high as 180 while running, however.
well, its probabally right diablo
I was shocked at first when I saw mine lol
im 35 and my max H/R ive hit 220, but because im not as fit as most, my avg H/R is a lot higher then others, I do about 160 on a day to day basis
I've said this at length before, but the whole 220 - age number is for a population. If you want an accurate max HR figure, you need to do threshold tests. I'm 29 and I've sustained 205BPM on a 20min FTP test, my max HR is roughly 215, so I'm miles away from any estimated figures, and if I were to use such figures to estimate training intensity I would be miles off!
Anyone doing spring South Downs sportive tomorrow morning? I'm heading down there, didn't manage to do an online entry but said on the day should be ok. It'll be my first sportive and first attempt at tackling any hills this year, but I'll be taking it easy so that my tendonitis doesn't flare up again
In a crit race I did last year I had an average HR of 173bpm over 27 minutes, maxed at 181bpm. I'd say it's fairly normal if you're pushing hard.
I'd DIE!
But I have that hill on my list to climb, first get my endurance up for distance then tackle it. I can do the Hill but die at the top will just make it pointless-ish... Maybe. Damn Spittal Hill.
It's the only way to get better at 'em unfortunately. Climb it, roll back down, climb it again.
You'll hear the phrase 'it never gets easier, you just get faster' a lot - the more I train the more I see the truth in it. It still hurts when i push myself hard on a climb, every bit as much as it did a year ago when i started cycling. However, compared to where i was a year ago, I go up the hills twice as fast, finish the ascent much quicker as a result and have the fitness that means i can recover more quickly and make it up the next hill too.
It's become strangely addictive - it hurts like hell when i'm doing it, but i actively seek out climbs now as i can't get enough of the feeling of accomplishment i get from completing them and getting faster at doing so.
I think i might have gone a bit wrong. :confused:
Yeah, that's definitely it. When you're grinding up a hill and every part of your body is screaming to stop but you don't until you're at the top, it's satisfying.
i've used a knee compression bandage on mine when i was in pain for a year, seemed to help tbh!
I've tried a cheap one from Boots, it seemed to help a bit, particularly in the cold weather. Just wondering if it's worth getting a decent one.
Nah, just raised my saddle, and made a conscious effort to use lower gears and higher cadence. My knees aren't 100% but they're a whole lot better than they were, and I'm not getting the twinges I was that had me literally wincing when cycling along. I'll be interested to see what else gets suggested at the bike fit.
I read somewhere that knee supports aren't really much good for cycling, because the forces you exert are just too great for the bandage to work properly.
My seat stem's welded to the frame, it won't budge.
I'll have to do some research on compression bandages, the last thing I want to do is make the problem worse.
Pretty much 1/4 there w/ plenty of time to go!
I'm struggling to do 50kms a day which simply isn't enough.
Yep. When you turn the final bend on Foxholes, you've already done 0.7 of a mile at between 5% and 15%, and then you hit the last 100 yards or so where it gets to more like 20%. Then you get to the top and you're like :D Fancy it sometime next week?
Status
