Caporegime
- 13 May 2003
- Warwickshire
Hi all
I just removed the old electric shower in our en-suite to replace it with a spare but better one we had lying around, and skillfully managed to break the plastic inlet tube as I tightened the compression joint.
Therefore I am after a new electric shower, but I want one that will deliver reasonable flow at a reasonable temperature, something I've not yet encountered with an electric unit.
Here's the setup:
(I've just added the valve, as it spewed water all over me when I broke the tube
Is it possible to tell from that picture whether or not the cable can support a 9.5 - 10.5 kW electric shower? The cable run back to the RCD is fairly long, 10m at a guess. The RCD has a 40A fuse and there's an isolator switch thing in the shower room.
Thanks.
Here's the setup:
)Is it possible to tell from that picture whether or not the cable can support a 9.5 - 10.5 kW electric shower? The cable run back to the RCD is fairly long, 10m at a guess. The RCD has a 40A fuse and there's an isolator switch thing in the shower room.
Thanks.
