Suspended
- 17 Oct 2011
- Buckingamshire
You mentioned having lower back pain the other day - it's possible you may need a shorter stem to reduce your reach given you already have a very neutral saddle to bar drop.
Looking at how short the stem is already and how far the seat is on the post, I'd suggest he needs a frame at least one size smaller and most likely 2 sizes smaller; go to a decent LBS and have a proper fit. That should allow the seat to be located properly and a longer stem to slow down the steering and eliminate the twitch that is naturally the result of using a very short stem.
currently i prefer sitting on it and i can reach the ground no problem.
I thought you'd disappeared into a ditch on a big alpine descent (or, more likely, collapsed into it on the way up
