The latest games: 1080p/60fps - £1k spec?
5 Dec 2010
Just what the thread title says. Would I be able to play the latest games at that fps and res and at high settings with decent eye candy switched on with a 1k spec build?
I mean the whole thing including windows monitor and periphs.
You could give the Windows 8 Enterprise (evaluation) Edition a bash for free on a 3 month trial. Infact I think they will do another trial for Windows Blue later in the year too. You can then buy the OS later having made an informed decision.....
YOUR BASKET
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £189.95
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £175.99
1 x Iiyama Prolite E2382HSD 23" Widescreen LED Monitor - Black £119.99
1 x Toshiba SSD HG5D Series 7mm 128GB Solid State Hard Drive - (THNSNH128GCST) £94.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
1 x XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply £54.98
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (CMX8GX3M2A2000C9) £53.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) HDD £47.99
1 x Corsair Carbide 200R Compact ATX Case - Black £47.99
1 x Logitech G500 5700DPI Gaming Mouse (910-001262) £39.95
1 x Thermalright Macho 120 CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
1 x TT eSports Challenger Gamers Keyboard £21.98
1 x Samsung SH-224DB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £1,000.76 (includes shipping : £12.50).
This 7870XT is a Tahiti core so closely related to a 7950, OC it and you net the same if not better performance than a stock 7950.
There is THIS larger SSD with cashback and it writes faster than it's 120GB lil bro. The Toshiba 128GB I have used is nice and rapid though. I look forward to seeing what you settle on in the end :D
YOUR BASKET
Whats the point in the SSD? Is it just to make the OS load up quicker?
I use mine for Windows and frequent used programmes, I would not go back to a mechanical drive, only for storage.
I would go for the HD7870XT over the normal HD7870.
When overclocked, its on par/better in some cases than a stock 7950 :)
I it easy/safe to OC your GFX card?
Yes very easy. It's done via software like MSI Afterburner for example. That's some cool software in itself as it has a GUI to show FPS,temps,GPU/VRAM used and you can also record gameplay. You can also set custom fan speeds to combat temps or noise (ideally balance the two).
Some GPUs are known to be good overclockers. Infact when you look at different models you'll note some are factory overclocked for you but you can often push them a little further. For example I still own a 1GB 460. Stock is 675Mhz, mine was Factory OC'd to 763Mhz, I've had her upto 900Mhz!! Ideally keep the max load temps no higher than 80 degrees and you are laughing :)
A good tip to keep your FPS up is to disable AA in the ingame menu. IF you don't mind tweaking settings, doing some overclocking and keeping your drivers uptodate you'll be surprised how much extra ooompf you can get from your kit :D
I'd say it would depend greatly on the game though.
+1 to MSI Afterburner, great bit of software.
True, though most of the time Overclocking the CPU only unlocks the bottleneck it has on the GPU (if any).
With my GTX 570, with my CPU overclocked to 4.7 i only saw a rise of 1 FPS (in Dirt3 and JC2). were as when i overclocked my 570 (ever so slightly) it gained 4-5FPS in each.
Afterburner is awesome.
Would it be worth going for one of those 8 core piledrivers instead, since the new consoles are gonna be 8 core?
Short Answer: No
Long Answer: The current 3570k performs better than the 8350 (8-core pildriver). The console 8-core CPU will be based on a Piledriver APU so won't even match up to the 8350 (no where near).
Even if they do start to port games for 8 core consoles i doubt this will translate to PC gaming quickly.
