a 790 could be a good card if it was two 770's on a board
I doubt it, my GTX 690s can do the proposed GTX 770 clocks without breaking a sweat.
All it would be is a rebadged GTX 690 with £50 added to the price.
All it would be is a rebadged GTX 690 with £50 added to the price.![]()
Or only if you actualy buy an ATI card, seeing as the last cards they made were the 5000 series, hence gregsters comment.![]()
only £50? bargain i'll take 4![]()
I think you misunderstood the original post you replied too.
When I said
The "re-branded cards with a slight performance boost and lower price" bit was aimed at the 680-770 re-brand, the bit after the full stop about the "cut down Titan" was separate, of course thats going to have a heafty price tag, but most likely one in between 680/Titan in line with its performance.
According to http://www.bit-tech.net/ the 8800GTS 512MB launched at $369.99 and the 9800GTX 512MB rebrand was $299, by the time the 512MB GTS250 launched at $129 the 9800GTX+ 512MB it was rebranded from was $149.
I'm not paying £500.00 or even close to, in my opinion silly money to spend on single GPU card just for gaming at 1920x1080
I'd consider the 770 if the price was around £300.00, which is highly unlikely.
You work for OCUK, just between you and me
What is the price of the GTX 780 going to be
I won't tell anyone honest.![]()
Just curious..
What would represent better value, An Nvidia Titan at £769.99. or a GTX 780 at £550? (rumored launch price)
Just curious..
You reckon a 620W Corsair HX would run two 760Ti's? Probably pushing it isnt it....
The gtx780 will easily be better value than titan. It should be within 10% slower at stock and many think it will overclock better. If it does overclock much better than titan, gtx780 max oc speeds could have the performance gap around 5% to a max oc titan.
Where the GTX 780 is starting from a higher stock clock the performance gap between it and a Titan could be as close as 5%
Having said that the above could also limit it more with overclocking headroom.
