i7 3770K idle temps high!
28 Jan 2013
well i re did my h80i thermal paste reseated and such today, and i know the paste usually takes sometime to settle to take full effect, but im idle'ing at 51c which i find bizarre i have OC'd from 3.5 to 4ghz though but not needed to change voltages,
has anyone had this with this cpu and cooler before or any suggestions to make it better, although when i have the cash i am thinking of either a swiftech h220 or a h100i to replace with.
just to add when not overclocked it will sit in 35c's but i want more performance i have seen the h80i perform well even with being a single rad, oh and my configuration is push pull.
its using 1.92-1.200v at load with 91c :(, it makes no sense though its using 1.264v in idle?
what board are you using? your proably using a fixed cpu voltage so you'll see high idle temps,you need to use offset cpu voltage then it will use less than 1v at idle
the voltage is on auto, so ill probs need to fix it to around 1.2 i would imagine and its a msi z77a g43
yeah,the lower the voltage the lower the temps,you shouldn't need much for 4ghz
its because its running full 4ghz and voltage = 51c at idle,when at stock clocks its entering idle state,offset allows the idle state while overclocked but I don't know msi boards at all so can't help you much on that
yeah i just watched a vid on my board theres another menu set which has a lot of seperate options for voltages and such so i can actually get to the voltage you said about haha thanks for your help much appreciated !
