** EXTREME COOLING AT OVERCLOCKERS UK **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
We have listed for pre order the entire range of EK Water Blocks EK-SF3D Inflection EVO Pots and accessories.
The range is going to be growing with new products added often such as new socket mounts and temperature probes.
This is the best way to get into Extreme Cooling.
EK Water Blocks EK-SF3D Inflection Point EVO @ £154.99 inc VAT
EK-SF3D Inflection Point EVO is a high performance universal CPU liquid nitrogen evaporation cooler for competitive overclockers.
CPU evaporation cooler only! Please order socket-specific mounting mechanism separately!
This product is a result of joint venture between Petri 'SF3D' Korhonen, legendary overclocker and extreme evaporation cooler designer from Finland, and EK design & engineering team. The product is made of electrolytic grade nickel plated copper in order to provide the necassery mass to even out the temperature fluctuation. Excellent weight to surface area ratio ensures confident controll over the temperatures even when cooling the hottest CPUs on the market. Top extension is made from black anodized high quality aluminium alloy.
The key feature that makes Inflection Point EVO evaporation cooler stand out from the pack is the new, socket specific revolutionary mounting system enclosure, making it easier for beginners to dive into the world of extreme overclocking while the veterans will surely appreciate the even clamping force.
EK-SF3D Inflection Point EVO key features:
- air-tight micro climate area inside the CPU evaporation cooler's hold-down enclosure
- perfect mount every time you install the evaporation cooler
- heating elements used to heat up the inside of the enclosure as well as the circuit board itself to keep the motherboard's VRM area as warm as possible
- fast remount turn-around - it takes less than a minute to swap out a CPU - perfect for binning the best CPU
- improved contact surface fits Intel's concave IHS of the CPU pefectly thus further improving the performance of the unit
- less insulation needed than with any other solution on the market.
Enclosed:
- EK-SF3D Inflection Point EVO
- Acetal hand-grip mounting nut with pre-installed 10W thin-foil heater
- Gelid GC-Extreme 3.5g thermal grease
Made in Slovenia - EU!
Heaters made in Hong Kong - PRC.
PLEASE NOTE:
- CPU evaporation cooler only! Please order socket-specific mounting mechanism separately!
- Evaporation cooler is being shipped dissasembled; user needs to join the aluminium extension to the core core by himself
- Insulation material is not included! Art eraser insulation method is not recommended. EK recommends either vaseline coat insulation method or using neoprene sheets.
- Thermal probes (wire sensors) are not included!
Only £154.99 inc VAT.
ORDER NOW
EK Water Blocks EK-SF3D Inflection Point EVO - Mounting LGA-115x @ £39.95 inc VAT
EK-SF3D Inflection Point EVO - Mounting LGA-115x is a LGA-115x socket mounting mechanism for EK-SF3D Inflection Point EVO CPU evaporation cooler. This item allows the EK-SF3D Inflection Point EVO to be used on majority of Intel LGA-115x socket based overclocking motherboards.
The product is made from precisely machined POM Acetal to fit past the nearby socket components and the socket area is sealed off with (o-ring) gaskets. Backplate is made from 3mm thick stainless steel plate. This product also features plastic standoffs which prevent excessive compression of insulation material as well as warping of the motherboard.
The installation requires the removal of LGA-115x socket's factory provides ILM (latch mechanism) and it's backplate.
Additional heater can be used on the backside of the motherboard's socket in order to further warm-up the nearby VRM capacitors for higher stability.
Enclosed:
- EK-SF3D Inflection Point EVO - Mounting LGA-115x adapter with gaskets
- EK-SF3D Heater 4W type A (LGA-115x)
- Backplate
- Front- (3mm) and backside (15mm) insulation sheet
- Mounting screws
- Required set of Torx- and Allen keys
Only £39.95 inc VAT.
ORDER NOW
EK Water Blocks EK-SF3D Triple Point EVO incl. Modules @ £64.99 inc VAT
EK-SF3D Triple Point EVO is a high performance system memory (RAM) liquid nitrogen evaporation cooler for competitive overclockers. Used in conjunction with up to four Module Adapters this unit allows extreme overclocking of virtually any (DDR-)SDRAM memory module (of any generation).
About EK-SF3D Triple Point EVO:
EK-SD3D Triple Point EVO is a product of joint venture between Petri 'SF3D' Korhonen, legendary overclocker and extreme evaporation cooler designer from Finland, and EK design & engineering team. The product is made of electrolytic grade nickel plated copper in order to provide the necassery mass to even out the temperature fluctuation. Top extension is made from high quality POM Acetal - with it's poor thermal conductivity it is better at preventing unwanted condensation formation that many overclockers are not fond of.
About EK-SF3D Triple Point EVO Module Adapters:
This product contains two (2) EK-SF3D Triple Point Module Adapter heatsinks. Each of these items are made of CNC machined high quality aluminium and feature black anodized finish. Each heatsink module consists of two separate plates while the DIMM memory module is sandwitched in between. Heat transfer between the memory module and aluminium heatsink adapter and copper base of the EK-SF3D Triple Point EVO is ensured by the use of enclosed Gelid GC-Extreme TIM (grease).
This product is ready to be used only with double-sided (single or dual ranked as per JEDEC) DIMM memory modules. In case single-sided DIMM module is used one needs to use 1.0mm thick thermal pad where no memory chips are used (not enclosed). Factory installed heatsink must be removed from each memory module prior to installation (if present).
Features:
- High performance evaporation cooler for competitive overclockers
- Modern, unique design with copper core allows for easy temperature regulation
- Built-in temperature probe slot in a each Module Adapter for precise control
- Compatible with both Liquid Nitrogen LN2 as well as Dry Ice CO2(s)
- Includes premium thermal grease
Technical data:
- capacity: 50mL
- weight (empty): 365g
- module adapter weight: 60g (each)
- operational range: -196°C to +80°C
Enclosed:
- EK-SF3D Triple Point EVO series evaporation cooler
- EK-SF3D Triple Point EVO Module Adapter (2 pcs)
- Gelid GC-Extreme 1.5g thermal grease
- mounting screws
- allen key 2mm
PLEASE NOTE:
- Intended for use with double-sided (single or dual ranked as per JEDEC) DIMM memory modules
- Factory installed heatsink must be removed from each memory module prior to installation (if present)
- Corsair® Dominator® and Corsair® Dominator® GT series memory modules are also compatible
CAUTION: For expert users only! Do not touch exposed metal with bare hands! Danger of severe frost burns due to extreme cold. Use in a well ventilated area! Do not use with liquid oxygen!
Only £64.99 inc VAT.
ORDER NOW
EK Water Blocks EK-SF3D Triple Point EVO Module - Black (2pcs) @ £21.95 inc VAT
EK-SF3D Triple Point EVO Module is a heatsink adapter which allows virtually any (DDR-)SDRAM memory module (of any generation) to be used in conjunction with EK-SF3D Triple Point EVO series liquid nitrogen evaporation cooler.
This product also features built-in temperature probe slot in a each Module Adapter for precise temperature control.
Enclosed:
- mounting screws
- allen key 2mm
PLEASE NOTE:
- This product can also be used with EK-RAM Monarch series water blocks
Only £21.95 inc VAT.
ORDER NOW
Looking great this one Rich. Certainly a less bulky revision of the SF3D pot I already own. The main problem with mine is it blocks slot one of the RAM slots.
These pots are great for temperature control and with the new mounting mechanism I cant wait to try one out at the Haswell Launch OC event at Computex in Taiwan.
Mansfield Cryogenics is where I buy it. Peter Wilkinson is extremely helpful in supplying me.
Hi Guys
tricky one this
Speaking to 8Pack who uses more LN2 than the Lager consumption of Ace Modder, you can buy LN2 from a chemical/gas supplier such as BOC.
They come to you and check you have the equipment required to store it safely and assess your competence in handling the chemical.
LN2 is a dangerous chemical and is obviously only for experienced enthusiast users and extreme overclockers, but you do not need a license to use it.
I thought u need a license ID for this due to UK health and safety law act as I used to work for health and safety promoter and it does ask for a proof ID (without it they are not allow to sell u this)
The Food Standards Agency (FSA) says bars, pubs and clubs have a legal obligation to make sure anything they serve to the public is fit for human consumption with ID license.
For a business you do need certification, health and safety risk assessments etc. I have the certificate but for home use its not necessary.
