Today Only Deals!
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £299.99 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Only £299.99 inc VAT.
ORDER NOW
Dell UltraSharp U3014 30" Widescreen LED Monitor - Midnight Grey @ £1,019.99 inc VAT
Users will experience outstanding color accuracy, precision and performance with the Dell UltraSharp U3014 30-inch monitor with PremierColor. The U3014 is Dell’s flagship high performance monitor with a 16:10 aspect ratio, suitable for the fine level of detail required for color-critical work such as CAD/CAM, graphic design, desktop publishing, gaming or media creation. In addition, users will experience stunning high-definition details and the ability to view more onscreen content with 2560 x 1600 resolution. More than just a high performance monitor, the U3014 offers flexible viewing options, versatile digital connectivity and is designed for exceptional efficiency with an eco-design that meets the latest environmental standards like EPEAT®, ENERGY STAR® and TCO Certified Displays.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- Light AG coating
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 10-Bit Colour
- 1000:1 Contrast Ratio
- 6ms Response Time (6ms Grey-TO-Grey)
- 350 cd/m2 Brightness
- DVI-D Input with HDCP support
- HDMI Input
- Display Port Input
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 3.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Smart Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
- Product Review @ TFT Central: http://www.tftcentral.co.uk/reviews/dell_u3014.htm
Only £1,019.99 inc VAT.
ORDER NOW
Features:-
- HDCP Support: YES
ORDER NOW
Features:-
Specification:-
- 30" Widescreen
- Light AG coating
- 10-Bit Colour
- HDMI Input
ORDER NOW
